need help identifying these broken parts
Old 06-17-2015, 06:35 PM
yamaha73's Avatar
So I'm new to the older Toyota game. Just bought a project 94 4runner 3.0
I'm replacing the head gasket and while taking apart found some broken parts I need help identifying thanks in advance
This is on the water bypass outlet at the rear of the motor. whats that plastic item between the hoses. It has two tabs missing from it one hose wasnt even attached and the other broke off
Hard too see theres two small rubber hoses that were just cut off and left.they each go to a metal tube that goes down the back of the driver side firewall. Kind of look like they go to the water bypass outlet somehow
This is the top of the intake manifold. On the right side that small tube with the big nut on the bottom. there was no hose attached to it when removed. Im pretty sure its for coolant but not sure where and what it goes to
This is my first gas engine rebuild so kind of a newb. Thanks!!!
Can't wait to drive this baby for the first time
Old 06-17-2015, 06:46 PM
Dennis140's Avatar
The plastic is a temp actuated vacuum valve for the evap system. TVSV I think is referred to as
Old 06-17-2015, 06:51 PM
yamaha73's Avatar
Thank you so much! Trying to order parts is difficult when I dont know what they are lol
Old 06-17-2015, 06:54 PM
Dennis140's Avatar
The two headed down driver side fire wall are for rear heater... You should only have a single level console and it looks like a metal tube is missing that they connect to.
Old 06-17-2015, 06:58 PM
Dennis140's Avatar
Rear heater core could have been leaking and they swapped out tubes to bypass it.
Old 06-17-2015, 07:07 PM
Dennis140's Avatar
Ok I see they bypassed it with the little black hose between metal tubes lol
Old 06-17-2015, 07:15 PM
yamaha73's Avatar
Sorry for the bad picture I can try to get a better one tomorrow. so my best bet would probably go to a pick and pull to replace I'm guessing
Edited: I apologize I did a little research now that I know that they are heater lines and found a fix
Old 06-17-2015, 08:00 PM
scope103's Avatar
I usually call it the "Thermal Vacuum Valve" (TVV). Here's the part number: 90925-05047 http://www.toyotapartsoverstock.com/...092505047.html Toyota sometimes calls it a "Bimetal Vacuum Switching Valve" (BVSV). Some on this site have repaired them, but the plastic top gets "rotten" with age and repairing it is tricky.
The vertical tube on the intake manifold connects to a water passage under the throttle body. There is another hose on the aft side of the throttle body that connects to the water bypass.
Old 06-17-2015, 08:14 PM
yamaha73's Avatar
Thank you guys so much. New to this forum and it's been a great help so far!
so the other hose on the throttle body would go to the TVV hose that I was missing possibly?
Old 06-18-2015, 06:57 AM
scope103's Avatar
Originally Posted by yamaha73
... so the other hose on the throttle body would go to the TVV hose that I was missing possibly?
Do we know which hose you were missing?
Old 06-18-2015, 06:19 PM
yamaha73's Avatar
So what do u guys think of this cylinder toward the bottom. Donso or....
mskalmus
05-28-2017 07:51 AM
rushw
07-18-2015 01:46 PM
88yodabasket
07-13-2015 01:32 PM
jon.r
07-11-2015 03:34 PM
akaphilly
07-09-2015 02:34 PM
Quick Reply: need help identifying these broken parts
