!!!!!!!!Need help with head gasket kit!!!!!!!!!!!!!!!!
Old 12-15-2014, 02:43 PM
culver89's Avatar
Exclamation !!!!!!!!Need help with head gasket kit!!!!!!!!!!!!!!!!
i just need to know if you guys think this will work for my truck i have a rebuild head 100% i know they had to shave it down some should i use a thicker head gasket like this one to help bc the one from autozone for 87.96 gasket set didnt work...... i just blown the head gasket today after being in for 6 months???????????????????????????? http://www.ebay.com/itm/85-95-Toyota-2-4L-Pickup-Oversized-Thickness-Head-Gasket-Set-22R-22RE-22REC-New-/200841186631?_trksid=p2054897.l4275
Old 12-15-2014, 03:31 PM
rworegon's Avatar
Well, it depends on how much was "shaved" off.
Many around here will say to get the kit from Tod at www.engnbldr.com and if you call with your situation you'll likely be taken care of in no time.
Old 12-16-2014, 01:01 AM
wyoming9's Avatar
Red face
Just where did the latest head gasket fail??
Might help to know just what went wrong.
Was the timing cover machined as well to match the head??
I would talk to Engine Builder see what Todd or Ted has to say.
Old 12-16-2014, 01:15 PM
muddpigg's Avatar
Good advice and my experience with engbldr.com is their products are really good quality. AND you can call them to ask for advice!!!
My last headgasket was actually from toyota.
Could be something other than the headgasket that is causing the headgasket to fail.
Old 12-16-2014, 03:07 PM
culver89's Avatar
well i have not had the time to tear it down yet will do this weekend i have no clue how much they had to shave off to fix the head i dont think it was much..... no the timing chain was not machined to match ??? do i need to do that ??? does anyone one know the best head gasket to use ? best quality? etc???
Old 12-16-2014, 03:10 PM
culver89's Avatar
the timing cover, all the bolt holes lined up and it fix nice and tight like before
Old 12-16-2014, 03:23 PM
muddpigg's Avatar
With our engines there is three parts that need to be machined to "match." Head, block, and timing chain cover. If the timing chain cover was not machined to same deck as block the head won't be flat and the HG will have weak spots in it from not equal mounting and pressure and so forth.
Did you flush out coolant system including heater before installing new HG? Debris has a tendency to settle out in heater. Turn on heater debris gets circulated and if pieces are big enough they'll clog HG and "blow it."
Did you ream out head bolt holes and get trash out of bottom of holes. Trash left in head bolt holes will prevent proper torque (well technically clamping force) of head and blow HG.
I'm sure there's more possible causes to premature HG failure but these are three that come to mind quickest.
As for the best headgasket, that question has been debated several times please feel free to search it and make your own assumption. Or three ppl in a row recommended engine builder or go to Toyota. Or go with autozone no skin off my back.
Old 12-17-2014, 02:21 PM
culver89's Avatar
Thumbs up
muddpigg........yes head and block are the same i didnt do the timing cover but it did set flush ,i did not flush the system ''i will this time!!!!!!!!!'', the only thing i can think of is they recommend to buy new head bolts and i did not buy new one i used the old ones from before so i think that might be my problem
........ thank you everyone for your input..... i will post picks when i tear it down friday...i went with the graphite gasket so we shall see what goes on from here!!!!!!!!
Old 12-17-2014, 06:35 PM
michaelphay's Avatar
I just bought that same kit but I also bought the head and bolts from them 293 total so hopefully I made a good choice
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: !!!!!!!!Need help with head gasket kit!!!!!!!!!!!!!!!!
