need help diagnosing check engine light
Old 11-12-2007, 03:13 PM
drpdmazda's Avatar
ok let me start off with the basics. i have an 89 4runner 2.2 RE automatic. sunday i replaced the starter because it quit working on me. after i installed the starter i started the vehicle to make sure i installed it properly and right away the check engine light came on. i disconnected the battery and let it sit a little bit then re connected it and it was still on. today i figured maybe i forgot to put the gas cap back on when i filled it saturday night but it was in place. i took the cap off which released some pressure then put it back on thinking that i may have had it too loose. the light stayed off for 2-3 blocks but when i got on the gas it came on again. i also blew through a half tank of gas to and from work where it normally takes 3 days to go through that much. i didnt see any disconected wires near where i was working on the starter so im kind of lost as to where to start looking
any help would be appreciated
thanks
jason
drpdmazda's Avatar
forgot to click the reply box
Old 11-12-2007, 03:23 PM
Jay351's Avatar
Did you pull the codes?
Look over your passenger side fender, inside the engine bay there will be a little grey box with "diagnostic" on the top. Open that. Now take a peice of wire or unfolded paper clip and jump the E1 and TE1 connectors.
Now go into the truck, turn the key to the run position and count the blinks of the check engine light. Have a pen and paper ready.
Old 11-12-2007, 04:35 PM
drpdmazda's Avatar
i dont have those exact numbers in my diagnostic box i have the following:
Fp
Cco
+B
T
Vf
E1
Ox
Lg-
E2
Tem
Ect
do you know which of those i would have to jump?
thanks for the help so far
jason
Old 11-12-2007, 06:06 PM
notanymore's Avatar
http://www.4crawler.com/4x4/CheapTri...CheckConnector
there is a detailed way of doing it and charts to what the codes mean.
and just a fyi the 22re isnt a 2.2 its a 2.4
Old 11-12-2007, 06:10 PM
drpdmazda's Avatar
ok thanks i will read over that site and see if i cant figure it out.
i dont know where the random period ( . )came from when i was describing the motor that was not intentional
Old 11-12-2007, 06:19 PM
'884Runner's Avatar
Just a shot, but on my previous 93 pickup, the knock sensor got disconnected when I put a new starter on it. I'm not familiar enough with the wiring and all on the 4runner's yet to know if everything hooks up the same, but just thought I'd mention that.
Old 11-12-2007, 09:05 PM
notanymore's Avatar
i was wondering if that was the case, but a friend of a friend swore up and down that his 4runner had a 2.2L engine in it so i thought i would put that out there
Old 11-12-2007, 09:23 PM
Jay351's Avatar
I think the 20r was a 2.2L but that was out before 4runners came along..
Old 11-13-2007, 02:31 AM
drpdmazda's Avatar
i was looking around that area last night as best i could with the rain and the dark i did find one plug that seemed to be loose but didnt find anything that it would plug into. i may try to get a pic of it and post it to see if anyone can tell me if it may have gotten pulled in the process
Old 11-13-2007, 03:03 PM
drpdmazda's Avatar
ok i got it figured out, pulled it in the garage after work and jacked it up. i did in fact pull out a plug and not realise it. after serarching for about 30 minutes i found the spot it pulled out of about an inch to the left oftheoil filter ( if oyu are looking at it ) there was a sensor that i pulled the plug out of, it was so difficult to find it because the previous owner painted the whole engine and the dillhole didnt bother removing the sensors he just painted them so the sensor was the same color as the engine block and just blended right in
thanks for the help folks
jason
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Yota.Jay
07-23-2015 08:08 PM
Kalihi,HI
07-09-2015 04:29 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: need help diagnosing check engine light
