Need help on clutch! (ASAP)
Old 03-02-2013, 04:28 PM
yota_94's Avatar
i have a 94 Toyota pickup with a 22re the slave cylinder was replaced and the clutch master cylinder was replaced. The slave cylinder is not moving the clutch fork and I tried bleeding it still nothing is working.
Old 03-02-2013, 04:31 PM
Roark's Avatar
Try checking out the clutch release bearing. It slides along the input shaft from the clutch fork pushing it. I'd try that bearing. It's located inside of the bell housing.
Old 03-02-2013, 11:00 PM
Philbert's Avatar
That doesn't make sense. The release bearing spins on the input shaft but does not compress when the clutch fork is pressed by the slave. My guess is this is hydraulic....
OP: have you tested the slave cylinder with it unbolted to see if it is working?
Old 03-03-2013, 12:50 AM
wyoming9's Avatar
Red face
We need to back up here.
What prompted the changing of the Master and slave cylinders??
What brand did you go with??
If this is a hydraulic problem either you have a failure out of the box or a poor connection allowing air to be drawn into the system.
Then no matter how much you bleed it you still have air in the system causing problems.
Old 03-03-2013, 04:54 AM
BamaYota1's Avatar
Look at your clutch pedal bracket to make sure everything is right inside the cab. They have been known to fatigue and/or break.
Old 03-03-2013, 06:33 AM
SHINE RUNNER's Avatar
when i replaced the slave cylinder on mine it did the same thing nothing so i took it off and looked inside it and the guts were gone where the line hooks up.nothing was in it.it was just a hull. take it off and look in the end where the line hooks up if its just a whole there then take it back and get another.
Old 03-03-2013, 06:37 AM
yota_94's Avatar
I used perfection slave cylinder and master cylinder
Old 03-03-2013, 07:43 AM
JD93TOY's Avatar
x2
I just took mine out and had a big crack in the upper left welded up in the last week. You may have to look really close, get your head up right under the dash with a light and inspect the whole bracket. Try to depress the clutch pedal with your hand while you're under there and see if the bracket is flexing.
kawazx636
10-06-2021 03:03 PM
primordialbeast117
12-19-2015 12:23 PM
smilen724
13
11-08-2015 04:11 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Need help on clutch! (ASAP)
