need help with broken rear axle shaft
Broke a rear axle shaft right at the hub. I can't find any info on how to go about getting the rest of the shaft out while it is still locked in the diff.
Any suggestions?
Any suggestions?
weld a bolt on the end of it and get a slide hammer and that should get it out, if no welder then u might be able to open the diff and see if u can get something in there to pry it out.
The rear axleshafts aren't "locked in the diff". There's nothing holding them in except the wheel bearings, bearing retainers, and snap rings. Follow the procedure for removing the rear axleshaft and wheel bearing, the remainder of the axleshaft will slide right out still connected to it and the brake backing plate assembly. Piece o' cake!
http://personal.utulsa.edu/~nathan-b...33rearaxle.pdf
BTW, you can't "open the diff" without removing both axleshafts first either.
What would you people do without me?
To the OP - what were you doing when it snapped? The stock shafts are very stout and they take a lot of abuse.
it slid right out with ease once I could get a hold of it.
Thats the kicker. I have 37's but I was just cruising down the street doing about 50mph. Haven't even ever wheeled it with the 37's.
I suspect the extreme heat weakens the shaft and causes it to break in that spot.
Of course if it had snapped "right at the hub", that would've meant the wheel came of while he was driving 50 MPH. And he probably would have mentioned that fact.
FS[PacNorWest]: Rear chromoly axle shafts
A2theK
01-10-2016 10:18 AM
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
