Need Help - bought 87 yota discovered leaking fuel and starting problem
Old 04-08-2014, 06:45 PM
newto22re's Avatar
Volts my bad hahaha
Old 04-09-2014, 12:39 AM
newto22re's Avatar
I have to admit I've never had an electrical problem that a fuse or something else straight forward (starter, alternator...) didn't fix. It may be time for me to let someone else figure it out. I'm definitely out of my league here.
Old 04-09-2014, 12:45 AM
newto22re's Avatar
And rokblok, I am very appreciative of your help! You're actually helpful lol. I'm in central Illinois.
Old 04-09-2014, 04:25 AM
rokblok's Avatar
I wish we could help further. I'm sure there are some RE folks that have more info.
As for us Southern folk, we would get a momentary toggle switch, and just wire that to the solenoid on the starter, from the battery. We might even do it with a relay, the "proper" way, if we were feeling frisky! Otherwise, some sort of industrial amperage rated toggle switch would suffice. Then we would turn on the key to power everything up, hit the toggle to engage the starter, and be on our way... No need/time for those silly solenoids and regulators and relays and crap...
Old 04-13-2014, 07:04 AM
  #25
wallytoo's Avatar
Originally Posted by Terrys87
One issue is the Starter Relay contacts get corroded. You can take the cover off and with a small piece of sandpaper, just do a quick touch up on the relay contacts.
if you get that far into it, you might as well replace the contacts rather than just sand them. they are probably worn, in addition to being corroded.
i've got a write-up (on t4r.org) about replacing the starter contacts in my '87. it isn't technically difficult, just awkward to reinstall the starter, since one of the clutch slave cylinder mounting points is the lower starter bellhousing attachment, too. link here http://www.toyota-4runner.org/classi...ep-thread.html
for electrical questions/advice/knowledge, check out some of RAD4runner's posts. ray is exceptionally gifted wrgt the electrical systems of these trucks.
Old 04-13-2014, 11:46 AM
  #26
newto22re's Avatar
Hahahah I like to call that redneck rigged. I might try that if I run out of ideas. Now it has a new ignition switch and coil. Still no start lol. I had my mechanic come out and he's pretty sure it's the clutch pressure sensor. Both the manuals I have now do not have an internal electrical diagram for the manual tranny though. Any idea where the clutch position sensor goes?
Old 04-13-2014, 11:58 AM
  #27
newto22re's Avatar
Thank you!!! I have to admit electrical is a bit out of my league. Ive never really had an electrical problem that something straight forward didnt fix. So I will definitely check out Rays posts.
I'm fairly sure that the fuel lines are switched. Sorry for this noob question but where are the posts for your 4runner, Terrys87??
Now it has a new ignition coil and switch. My mechanic came out and he's fairly sure it the clutch pressure sensor. I have an override switch ordered and on its way. Any idea where the clutch pressure switch is on these guys? I'm not locating it in either of the manuals that I have.
Btw - I said 12.46 amps earlier. I meant 12.46 VOLTS. Woops hahaha
Thanks a bunch guys.
Old 04-13-2014, 03:49 PM
  #28
wyoming9's Avatar
Red face
It is on the clutch pedal bracket.
If you get your head down under there and look up you will be able to see it.
One of the first things I remove.
Old 04-13-2014, 05:35 PM
  #29
rokblok's Avatar
The clutch position switch should be on the clutch pedal, down under the dash. But I believe there should be a clutch bypass switch on the dash, to the left of steering wheel. Make sure it's out of gear, because if it cranks/starts, it'll be heading out of the driveway... Or through the house... Or you could push in the clutch and hit the switch just to be sure. I'm sure you can bypass the switch, but I'm not sure how. Do search here and/or google and there should be instructions. I'm sure it's just a jumper wire. (I'm going off of pure, short memory here...)
On a side note, in another thread, 85turborunner mentioned that the silver finned box on the passenger wheelwell, is a injector resistor box. I don't believe it would have anything to do with cranking. But search up on that subject.
Old 04-13-2014, 06:07 PM
  #30
Fossilized
Staff
dropzone's Avatar
Duplicate threads merged.
In the future please don't create multiple threads on the same subject
duckhead
170
11-13-2017 06:07 AM
voiddweller
19
05-02-2016 09:10 PM
bigblue82
10
07-06-2015 08:27 AM
shredder4286
06-27-2015 09:42 AM
Quick Reply: Need Help - bought 87 yota discovered leaking fuel and starting problem
