Need Help ASAP!! Headgasket Job / low compression on Cyl. 3
So I got done doing a head gasket job on a 3.0 Toyota, truck ran fine coming in. When I was cleaning the heads I had a couple of shims / lifter cups fall out. I thought I got them back in there normal spot but it appears I did not. So I did a compression test, all Cyl. came back great except for Cyl. 3. So I checked all valve clearances and everything was in spec except for cyl. 3.
I ordered the smallest shim I could get the 2200, put it in and I now have around 95 PSI of compression in Cyl. 3. My question is this should of fixed it. Also, are the round cups that the shims fit into different sizes? What else could be causing low compression?
Thank you
Thank you
Was any valve work performed? If so did they replace the seats? Use the right ones? Anyways the head shop I use adjusts the valve clearances by grinding a little off the valve ends. A lot easier and cheaper. Should have no issues
No valve work was done. Just checked for warped, and cracks.
I did some more testing, I checked valve clearances and exhaust side is way too tight on Cyl. 3. So I got some new shims but its still too tight even with the smallest shim in there. One thing I did notice is when the cam lobe is all the way up, that lifter cup sits way higher than the others that are also pointing up. It seems like carbon build up or something is keeping that valve open not allowing it to close. What do you guys think?
defrag4
07-31-2015 10:50 AM
