Need help on 22re!!!
Old 06-22-2008, 06:40 PM
truckpuller's Avatar
Just bought an 88 yota with the 22re engine. The truck did not run when I bought it. The guy told me he bought from a kid and drove it home 30 miles and it it ran fine until he washed under the hood then it quit. That was 8 years ago. I started with a new battery. Then I drained the 5 gallon of water out of the gas tank and what little gas was in it and cleaned the dirt out of it and install a new strainer on the pump. New fuel filter,plugs,wires,cap,rotor,etc. That got it so it would start and it idles perfect but thats it. As soon as you start to open the throttle it starts to stumble and run rough. I test the tps checked fine but i tried a different one anyway. I tried a different air flow meter. Tried a different distributor. Different coil. New ignitor. Different computer. Any other ideas? It did run better with the air flow meter unplugged??
Old 06-22-2008, 06:41 PM
Countryhick's Avatar
The only thing i can think of is your distributor got wet.
Or you got water in all your filters and blew your engine.
Old 06-23-2008, 03:38 PM
ahickman's Avatar
Any codes? Did you check for obstructions in the intake (rat nests) or leaks around the intake?
Old 06-23-2008, 05:16 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
"Different" airflow meter? As in not new? Are you sure the AFM replacement was good?
JNapolitano
11-14-2019 07:46 PM
Stull
08-28-2015 05:53 AM
ia02
08-20-2015 11:04 AM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: Need help on 22re!!!
