Need FSM Temp gauge resistances '88-89 V6
Old 08-29-2011, 08:00 PM
Staff
DeathCougar's Avatar
Anyone with an 88-89 4Runner or 88 Truck FSM, I need resistance readings from the BE section (mine was BE-29 for a 4cyl 87). System is under Instrument Gauges/Warning lights
I have a tach.
It has to be 88-89 4Runner or 88 Truck V6
My 87 book says: IG-TU 135, TU-E 138, IG-E 273
We are trying to track down a temp gauge issue, but I only have an 87 FSM
Thanks!
Old 08-30-2011, 10:50 AM
angrybob's Avatar
Knowing what you said above, I've attached the '90 3VZ water temp gauge repair manual section on pdf if it helps...might.
File Type: pdf
Old 08-30-2011, 12:05 PM
Staff
That doesn't apply to my setup.
I think I have tracked down an 88 manual, which lists the same testing procedures as my 87 manual. The 87 and 88 gauges are also listed as the same part number by Toyota through 02/89.
The truck my gauges came from was 08/88 V6, VN66 Chassis.
Old 08-30-2011, 12:40 PM
xxxtreme22r's Avatar
I believe 92 Toy has the hard copy for his 88 4runner. As you said the downloadable 88 FSM from ttora only has the 4cyl info. Same values you have listed above. I don't see them being any different then the 4cyl though. Since the only thing really different is the Tach. IIRC the part number for the gauge sender is also the same between the v6 and 4cyl. 83420-20020
Old 08-30-2011, 01:18 PM
Staff
The FSM should cover both 4cyl and V6 in one repair manual.
I will talk to Jerry and see what he has.
Old 08-30-2011, 01:20 PM
the downloadable mentions nothing about the 3vz. Just the 22r, 22re and 22rte. aka RN chassis not the VN chassis.
Old 08-30-2011, 03:45 PM
Staff
Really? NO one on Yotatech has an FSM for an 88-89 4Runner V6?
Maybe people don't work on them anymore
Old 08-30-2011, 03:47 PM
isn't the 3vz a throwaway motor? I coulda swore Jery had one for that 4runner and not just the 92.
Old 08-30-2011, 04:16 PM
Staff
The 3VZ is a throwaway motor.
I swapped in a 5VZ, and changed clusters. Try and keep up here
Old 08-30-2011, 04:29 PM
hey where was the 5vz mentioned in this thread? Incomplete info will lead to incomplete answers. lol. Anyway, which sender are you using the one from the 3vz or the 5vz? Or are they the same ones? If the 5vz one is different the the 3vz sender you sure the sender is compatible with the 3vz cluster?
Old 08-30-2011, 04:48 PM
RMA
RMA's Avatar
not sure what year this is for just have it under 3vze manual on my computer.I dont think it matters though
Old 08-30-2011, 05:09 PM
92 TOY's Avatar
Josh....maybe hit up the Baller.....he has one of those fancy accounts, probably could access.
i searched and only found a repetitive link to something called "rapidshare" file sharing that costs $$$$ to download....if that is even the right one.
why do we have an 88 4runner with a 3vz and the 88 manual covers only the 4cyl? the 92 FSM does NOT differentiate between motors when it comes to the all inclusive cluster.......so for that year, at least, the stuff is the same.....if i am reading into this correctly.....only 1 section and 1 set of instructions.
BODY ELECTRICAL page 36 in my manual is the same as the pic above.
this is all i have from HAYNES.....the it directs you to wiring diagrams but no resistance values
Old 08-30-2011, 08:19 PM
Staff
You posted 89+ Truck 90+ 4Runner. They are completely different gauges, different wiring, etc.
That doesn't help, but I appreciate it!
I checked with Baller, he has nothing either. Apparently book is impossible to find!
Old 08-30-2011, 08:32 PM
BigBluePile's Avatar
Put an aftermarket one in it. Geezus.
Um...belay that....OEM Nazi....Hmmmm.....did you try kicking it?
Old 08-30-2011, 08:43 PM
totally a bro
Staff
vital22re's Avatar
I may have "love tapped" it ... with my fist... out of pure frustration.
Old 08-30-2011, 08:55 PM
RMA
RMA's Avatar
this is off my Toyota electrical wiring diagram truck and 4runner 1988 model book .. it only has the values for the sender though not the gauge .. but may help some.
good luck !
Old 08-30-2011, 08:58 PM
MK3Supra's Avatar
Post
I have a tach.
Thanks!
The resistance is (146.6 +26.5/-4.0 at 140F)
(24.3 +1.3/ -1.8 at 239F)
Old 08-31-2011, 06:38 AM
Deathcougar?
Old 08-31-2011, 07:20 AM
Staff
That is EXACTLY what I needed. 88 V6 aka VZN FSM.
So now I know for 100% sure that 88 4CYL and 88 V6 gauges read the exact same.
Winning!
Old 08-31-2011, 09:58 AM
Soooooooooooooo...does that mean you could use a '88 4cyl cluster then?
Last edited by BigBluePile; 08-31-2011 at 09:58 AM. Reason: Don't give a dumb answer either DC....:D
Quick Reply: Need FSM Temp gauge resistances '88-89 V6
