need exhaust manifold torq specs please
Old 08-28-2008, 12:09 PM
ThomasTedder's Avatar
Does anyone know the torq specs and if there is a particular tightening order?
Old 08-29-2008, 11:44 AM
Swansen's Avatar
oops, i meant to get to this yesterday, but its 33 ft lbs
Old 08-29-2008, 05:14 PM
Matt16's Avatar
33ft-lbs. There is an order but your fine just tightening the bolts in a bit of a criss-cross pattern. Tighten them to 20ft-lbs, then to 33lbs, use anti-seize.
Old 08-30-2008, 02:05 PM
Thanks guys.
Old 08-30-2008, 02:46 PM
toyota-erik's Avatar
Just tighten it until it starts to strip and back it off 1/4 turn. Then weld them so they never come loose.
Old 08-30-2008, 04:51 PM
Swansen's Avatar
Yes, while your at it, you might as well just weld the head to the block also, that way you'll take care of any possible head gasket leaks....
Old 09-02-2008, 12:05 PM
I can't believe I never thought of that.
Jayboy74
10
12-21-2021 08:27 AM
Corvoid
09-04-2015 11:55 AM
shrek99352
08-31-2015 04:16 AM
Quick Reply: need exhaust manifold torq specs please
