need a coulpe plugs from 22re harness
Old 07-22-2008, 04:34 PM
kd
kd's Avatar
i need 2 injector plugs and the plug for the sensor on the thermostat. not sure if that last one is a coolant temp sensor just cuz i have another thermostat housing that dosent have a port there so... anyways all the yards by my house have no toyota trucks and yards that do only sell complete harnesses. so if you can go snip them for a yard near you let me know and ill make it worth your while just make sure to leave as much wire intact as possible. its for an 86 4runner 22re pm me if you can help thanks!
Old 07-22-2008, 08:21 PM
myyota's Avatar
It helps to know were your located.
Old 07-23-2008, 02:39 AM
HAVOC's Avatar
Do you need the connector itself or the connector with some length of wire? I have a 3.0V6 and when I pulled the engine out the injector connectors were brittle and broke.
I bought 6 from from Lexus (I work there) for $4.00 a peice. I can post the part number if you need it.
Old 07-23-2008, 07:14 PM
kd
kd's Avatar
sure are they the type of connector with the metal clip? theyre for a 22re.
Old 07-24-2008, 08:01 AM
4Hummer's Avatar
Injector Plugs for a 22RE come in Two Flavors Round and Rectangle Which do you have ?
I should have all 3 that your looking for depending on the Style of injector plug
MO transplant
04-23-2023 11:58 AM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
Doug4320
03-24-2018 10:11 PM
msane99
07-17-2015 10:13 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: need a coulpe plugs from 22re harness
