need advice on the trail rig
Small concern right now is tire size so I can decide gearing.
Do any of you run a 34 inch tire? More to the point do any of you run the 34/10.50/15 Super Swamper LTB?
http://www.intercotire.com/tires.php?id=7&g=1
I'd like to run that tire on the 89 4runner with the 1.5" bj's up front and ZUKs 100lb coils in the rear. I'm doing 5.29 gears and locking the front and rear and if these tires will work worth a darn on rocks then I don't have to buy new wheels and can use that money for other things.
This is going to be a trail rig with limited driving on the street during the summer but I need to be able to drive to and from the trail head. I'm guessing these tires are going to be loud on the street but that's not an issue.
Thank you
Thank you
sounds like a good ideer. i'm going to be going for some super swampers soon probly a 36 tho. you should be happpy with that gear/tire combo. i dont have much to say about the 34 or the ltb
ratio and tire size should be good as i have seen others running similar setups...as far as the swampers they are loud as all hell, my buddy has a set...as far as a 34 i have no info.
Check with TC. I know he did for a while.
https://www.yotatech.com/forums/f177...per-ltb-86364/
You'll probably be OK if you're going trail only. (or minimal street) A bunch of the guys here have various iterations of Interco stuff that they drive to the trailheads without too much complaining. Along your lines I'm thinking about the TSL Q78 for a trail tire. I'm still a ways away from having to actually pull the trigger on that though. We'll see.
