Need advice on axles
Hello I am new to toyota pickups and cannot figure out where to get a axle. I have a 1989 2wd 22r single cab pickup. My axle snapped on the highway and well did some damage. Cosmetic I do not care to much about but I need to get it running. I have a 30 spline 5 lug axle that I cannot source anywhere. I only been able to fine 6 lug 30 spline. Does anyone have a axle that they are willing to part with or know where I can get one? I have seached the forums and the net and not def answer.
Broke going down the highway? Sounds fishy.
Got pictures of the breakage?
Heres some for sale: https://www.yotatech.com/forums/f11/...s-50-a-283247/
A lot of the Toyota axles break when the axle/wheel bearings siezes and twists the axle shaft apart.
More than likely will need bearings/seals along with your axle repair.
Could just get a replacement entire rear axle assembly.
Definatly tons of axle parts for these trucks out there just need to search a little more.
A bearing failing and taking out an axle is one thing just breaking a axle is something else.
I will say ok the OP failed to mention the rear wheel bearing failed .
In my case the axle was fine it and the tire just rolled right past as I wondered what was going on the right rear of the truck hit the road.
It was at night and the sparks were really pretty
I would look at the groove in the road for years till the road was resurfaced in a make union work project.
polo451
13
11-20-2016 07:49 PM
WTB[MidWest]: Looking for 5spd harness, front axle- 1990 truck
dfarr67
07-30-2015 07:08 AM
