| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Name that Part!!! (22re w/picts)
__________________
86' 1-ton Stock Everything!! No plans to do anything with it except keep it alive until my grandkids can drive it. Last edited by PDX_1ton; 11-24-2008 at 09:32 PM. |
#2 (permalink) |
That looks like the oil pressure switch/sender depending if you have the oil pressure guage or idiot light on your cluster.
__________________
1989 Toyota 4runner Special Edition - Rebuilt 22re bored .20 over 4.30 gears, - Magnaflow Performance Exhaust with Magnaflow Hi Flow Catalytic Converter, Monroe Sensa-Tracs Shocks all around, 4runner AALs, Custom Checkerplate front skid plate, Kayline Soft Top , Clear Corners and Turn Signals, Eagle Alloy Rims with 31x10.5x15 M/T tires, 2 12" JBL Subwoofers / MTX AMP, Pioneer Premiere Speakers, JVC KD-G730 MP3/CD/Bluetooth |
#3 (permalink) |
That is the oil pressure sender for a NON-SR5 truck. Its for the idiot light on the dash.
__________________
Scotty http://www.addictedoffroad.com/ 970-420-4198 Toyota Winch bumpers on SALE! |
#4 (permalink) |
Eightnine and ScottyC, which pict are you referencing?
__________________
86' 1-ton Stock Everything!! No plans to do anything with it except keep it alive until my grandkids can drive it. Last edited by PDX_1ton; 11-24-2008 at 09:20 AM. |
#5 (permalink) |
ditto what they said.
__________________
1987 Truck, tube frame flatbed, homemade bumpers, stockish running gear, Aussie locker in rear-end, bronco tire carrier, 36" Swampers on American Racing Baja 16x8's, 1.5" BJ spacers, rear lowered 1" with u-bolt flip, Summit racing seats, long travel front shock mounts, 8000 lb winch, rear frame mounted gin pole, several ammo boxes for storage, air tank, snorkel, smokestack, 4.88s, 1" aluminum body lift. and lots of skulls. check out my truck Senate Minority Report on "Global Warming" |
#6 (permalink) |
i mean ditto what ScottyC said
__________________
#7 (permalink) |
They are referencing the bottom pic. Can't really see what you are pointing at in the top pic.
Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd) Rancho lift w/ 33x12.5x15 tires & 5.29s |
#8 (permalink) |
Yeah I'm refering to the bottom pic, I don't see whats going on in the first.
__________________
#9 (permalink) |
Ok I lightened and blew up the #1 pict to show what the arrow is pointing at a bit better.
__________________
86' 1-ton Stock Everything!! No plans to do anything with it except keep it alive until my grandkids can drive it. |
#10 (permalink) |
Oh it looks like it could be the knock sensor.
Edit: Wait maybe not Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd) Rancho lift w/ 33x12.5x15 tires & 5.29s Last edited by rdlsz24; 11-24-2008 at 09:49 AM. |
#11 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
first pic looks like the coolant temp sensor for the gauge- directly below that sensor (lower side of manifold) is the coolant outlet that runs to the heater core
second looks like the oil pressure sender
__________________
Quote:
Insomnia: it's a way of life.
#12 (permalink) |
in agreement with abe
__________________
1988 4x4 Pickup ISR/Battery-Intake Swap/216"c" Cam/ EGR removal/ |
#13 (permalink) |
Thank you Abe and Blackspyder. (Making changes)
__________________
#14 (permalink) |
I love the "name this part" game, but I'm always too late and someone answers before I can
__________________
91 PU, 4wd, manual, 22re, .30-over, engnbldr RV head and 261 cam, MC 1200lbs clutch, misc LCE, engnbldr, and MC parts and HW, Pacesetter header and exhaust kit, Rancho UCA's , 4Crawler 1" diff and sway bar drop and 1.5" BJ spacers, WabFab 3.5" shackles, 31x10.5 pavement-pounding ATs on ProComp Extreme Alloys, misc SR5 interior goodies swapped in, 1000watt stereo system MySpace |
#15 (permalink) | |
Quote:
Quick thought...if the oil sender unit was already unplugged, it may be for a reason. If you're running a tach on a non SR5 pickup, you have to switch out the sender unit. Otherwise, you'll burn up the gauge. If previous owner swapped in a tach from an SR5, he may have just left the oil sender unplugged rather than swap in a sender for a gauge. Just something to think about.
__________________
-- 1987 4Runner SR5 22RE with AT (God Help Me) 195,000 Miles Bone stock save front bumper |
#16 (permalink) |
the round thing is for an oil light or a guage, it looks like the one for a light on the non tach equiped guages
__________________
94 pickup 4x4 22re |
#17 (permalink) | |||
Quote:
I do hope that if I'm wrong you will correct me though, okay?Quote:
__________________
#18 (permalink) |
Quick thought...if the oil sender unit was already unplugged, it may be for a reason. If you're running a tach on a non SR5 pickup, you have to switch out the sender unit. Otherwise, you'll burn up the gauge. If previous owner swapped in a tach from an SR5, he may have just left the oil sender unplugged rather than swap in a sender for a gauge. Just something to think about.[/quote]
Nope I unpluged it myself, then took a picture. Good notes about the Tach as I was considering putting one in.
__________________
#19 (permalink) | |
I didn't know the intention or destination, and that's why I called it the 'oil pressure sender'. Either way, whether simple 'idiot light' or 'pressure gauge on the dash', they both plug in to the same wire and install into the block at the same spot.
Considering the write up is about a 22re, in general, the ancillary devices should likewise be 'in general'. "Disconnect (this) because you may have (this). If you don't have (this) you have nothing to disconnect." Catch my drift?
__________________
#20 (permalink) | |
Quote:
__________________
#21 (permalink) |
OK folks we are almost there. Only two left. Here are the toughies, there are no pictures. Where are the following two items.
(f) Vacuume switch/wire (h) Starter wire (Don't hate me for this one, I get confused between the high lead, ignition coil, and about 30 other things)
__________________
| Tags |
| 22re, destination, knock, sensor, wire |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22RE part question | Ares | 84-85 Trucks & 4Runners | 11 | 09-09-2008 08:51 AM |
| 1985 & 86 4runner in GA with picts... | basr5 | The Classifieds GraveYard | 1 | 01-27-2008 05:55 PM |
| A few quick fire road picts | Mikestang | Trip-Trail Reports & Photos | 5 | 08-08-2006 11:24 PM |
| Magnaflow cat-back picts & write-up | Mikestang | 03+ 4Runner/GX470, & 05+ Tacomas | 22 | 07-14-2006 12:16 AM |
| any picts of yotas body less | tricken | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 09-09-2004 02:29 PM |
