Mystery miss in 88 pickup
Old 09-18-2009, 09:26 AM
pooldoo's Avatar
My '88 Toyota pickup 22RE 2WD (65k original miles) is running on 3 cylinders - missing on cylinder 3. Removing the spark plug wire at idle has no effect. Compression is 175 for all cylinders, getting a good spark, new spark plugs, fuel injectors have been removed, checked and replaced. You can hear injector clicking with a stethoscope. Air flow meter, power relay, fuel pump relay, fuel filter all replaced. Suggestions, please. I'm desperate.
Old 09-18-2009, 10:16 AM
pooldoo's Avatar
Mystery solved
Never mind. We found crud in the fuel rail, and all seems ok now.
Old 10-29-2009, 01:34 PM
03vrod's Avatar
Did you remove the rail when you found the crud.My truck is doing the same thing checkedspark ,injector,valves,added injector cleaner.So I'm considering tearing intake apart to check
icentropy
09-16-2020 02:47 PM
shisha1999
03-16-2016 12:25 PM
09-04-2015 09:27 AM
Yota.Jay
07-23-2015 08:08 PM
Quick Reply: Mystery miss in 88 pickup
