mysterious wire / cable / sensor ?? behind dash
Old 01-18-2008, 01:10 PM
Chrisnxl185's Avatar
I was replacing my shifter bushings today and removed the plastic cover right in front of the shifters and found a strange looking wire / cable
My truck runs fine, theres no problem i'm just wondering what it is
Old 01-18-2008, 01:11 PM
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
fm antenna
Old 01-18-2008, 01:19 PM
so thats the end of the antenna or should that be plugged in somewhere? It seems like my fm antenna shouldn't be sitting on the floor.
if it help is have an after market head unit
Old 01-18-2008, 01:26 PM
that should plug into the back of your HU. has your radio been working or do you have an aftermarket/second antenna of some sort?
Old 01-18-2008, 02:06 PM
Guest
seanz0rz's Avatar
it is the rear glass embedded antenna connector, used by stock headunit, but most aftermarkets dont support it.
4runners came with a diversity antenna setup to improve reception, one on the fender, one in the rear cargo glass. disregard that plug if you have an aftermarket setup. it is fine to just leave sitting there.
Old 01-18-2008, 08:27 PM
longhungsilver's Avatar
very interesting, good to know
jasonty
41
12-23-2018 01:00 PM
88yodabasket
07-13-2015 01:32 PM
Johntom240
7
07-13-2015 12:18 AM
smiley52
07-11-2015 05:16 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: mysterious wire / cable / sensor ?? behind dash
