My Weekend mods
Old 06-06-2008, 07:15 AM
Belize Off Road Team's Avatar
Post My Weekend mods
Well since my winch arrives on Monday (Taking FOREVER) i have time on my hands this weekend and i have decided to Remove my Cruise Control system and move my intake to where the cruise control was.
i have 3 reasons for doing this change,
1 is to raise the intake level till i get a snorkel
2 is to make room in the front for a dual battery in the future
and 3 my cruise control doesn't work properly anyways.
I have a few questions,
When removing the Cruise Control system, is there anything i have to be worried about? just remove the fuse and then the units under the hood right? any lines attached i should be concerned about when removing, like a vacuum hose?
I'll post pics as i go along and what parts i have to buy to move the intake.
Old 06-06-2008, 09:31 PM
just a 22re's Avatar
the vac lines yes you would need to cap them off other then that nope rip it off and put it in the corrner lol
Old 06-06-2008, 11:14 PM
yotasavg's Avatar
hey i'm interested in seeing this done! good luck this should be cool, i've been thinking about ditching my cruise as well, but i'm thinking it's a vacuum issue so i could just fix it......
Old 06-07-2008, 04:44 AM
plumo57's Avatar
In terms of vacuum, is there anywhere that i can get a vacuum line diagram? My cruise doesn't even work, and i have a vacuum line thats not hooked up on one end and i can't figure out where it should be going.
Old 06-07-2008, 05:39 AM
I had planned on plugging the end of the vacuum line anyway just in case.
I disconnected the "Speed Control" box under the driver's kicker panel last night. Today i am going to remove the Actuator and Vacuum. I'll post pics once i'm done.
Then i have to measure the Intake box to ensure it will fit, and with minor modification i think it should be no problem.
plumo57: check the FSM stickys for a diagram. All i can tell you is the lines go every which way.
Old 06-07-2008, 08:31 AM
*UPDATE*
I removed the acctuator and Vacuum, Here are some pics:
On monday i am going to go to a local Auto Store and hope they have some intake tube that bends towards the rear rather than the front so i can move the intake. Also monday i get my winch so the intake will probably be put on hold
Old 06-07-2008, 08:36 AM
And all i used as:
1/4" Ratchet
10mm Socket
6" 1/4" Extension
Took me maybe 1 hour to do it, i had to make sure nothing else was connected and everything was plugged or covered.
TheBFA
02-15-2020 06:55 AM
Gravel Maker
RuffStuff
10-04-2015 10:26 AM
oldblue
09-28-2015 04:07 PM
Project90
09-24-2015 11:40 PM
Quick Reply: My Weekend mods
