Is this my water pump leaking?
Old 05-06-2007, 04:49 PM
CenCalRunner's Avatar
I have had a small but steady coolant leak for a couple of months now. I went offroading today and it got way worse. The coolant appears to be coming out just above where the lower radiator hose connects to the engine block. It doesn't leak when the truck is running, but as soon as I shut it off, it pours out. Is it my water pump?
Old 05-06-2007, 05:19 PM
My814x4's Avatar
Sounds like it is , thats where the weep hole is located
Old 05-06-2007, 05:21 PM
tell me more about this weep hole. i'm assuming this isn't normal? am i looking at replacing the water pump?
Old 05-06-2007, 05:25 PM
leebee's Avatar
yup and you should think about doing the timing belt etc while you are in there. plenty of threads on that subject, search away young luke.
lee
Old 05-06-2007, 05:39 PM
ChickenLover's Avatar
This should give you some idea of what's going on under there.
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
Snort
07-19-2015 07:03 AM
Jonny246
07-12-2015 04:51 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: Is this my water pump leaking?
