| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#51 (permalink) | |||||
#52 (permalink) |
so i dove intot the 3rd member today and found some strange things...1st off the ring gear had 37 teeth, and the pinion 9, whichs makes it 4:11s,odd knowing mostly all toyotas came with 4:10s...secondly it had a solid spacer not a crush sleeve. i didn't think toyota had solid spacers stock. also there was bearly ANY wear on any parts in the 3rd, as if 4wd was bearly ever used. and come to think of it when i 1st disasmebled the axle i remember there being a stock toyota 3rd gasket. any input
__________________
1989 4runner 3.0L,5spd swaped,Marlin HD clucth,v6 to gear t-case,dual case x-member,chevy 63's,1" blocks,u-blot flip,shock trianglation,Marlin rear bumper,sliders,1"body lift,soft top,welded rear,steelies,33"BFG MTs,SAS frt w/ RUF--->http://www.yotatech.com/f116/my-very...runner-143762/ Destination...OFF ROAD
#53 (permalink) |
im dropping my 1st gen off tomorrow, pick it up in a few months sound good? cool...lol
runner looks great, i have a lot of similar plans, and i plan on using a lot of the pictures and information you posted up to help with mine. thanks! and good luck on the SAS, i was quote 3k to have mine done, id do it myself, but i cant weld...hoping that if i put together and rebuild the SFA they will come down on the price. |
#54 (permalink) |
im good on a budget....really only run me about $800 or so without the price of the axle, so with the axle about $1,000.
__________________
#55 (permalink) | |
Quote:
factory 4:11s and a solid spacer not a crush sleeve.
__________________
#56 (permalink) |
i don't know what year your third is, but when i rebuilt one for my rear end i used one from an earlier truck(81 i think, it had 3.90s) and it had a factory solid spacer, cast iron lookin' thing.
i think crush sleeves came out later sometime?
__________________
1987 Truck, tube frame flatbed, homemade bumpers, stockish running gear, Aussie locker in rear-end, bronco tire carrier, 36" Swampers on American Racing Baja 16x8's, 1.5" BJ spacers, rear lowered 1" with u-bolt flip, Summit racing seats, long travel front shock mounts, 8000 lb winch, rear frame mounted gin pole, several ammo boxes for storage, air tank, snorkel, smokestack, 4.88s, 1" aluminum body lift. and lots of skulls. check out my truck Senate Minority Report on "Global Warming" |
#57 (permalink) |
huh.?. the axle is an 82...maybe pre-84 they where like that
__________________
#58 (permalink) |
i've seen a few others before, and i think they were all first gen trucks.
good thing you got one, i think crush sleeves are kind of a pain, especially if you muck one up. what ratio did you say you were gonna run?
__________________
#59 (permalink) |
front: 5:29s open(for now)
rear: v6 case, 5:29s, detoirt(gonna get a solid spacer) the front is eventualy gonna get a v6 e-locker
__________________
#60 (permalink) |
slowly picking away at the front axle still...but you all shall have pics tomorrow
__________________
#61 (permalink) |
here's a pic of the axle housing...it's just cover in dust right now...
![]() abd the 3rd cleaned up and painted... ![]() all that's left to paint is the hub boddies(where the caliper bolts to) i'm using rustoluem brand primer+paint casue it's nice,thick,and druable.also i'm 2 toneing my suspension parts black and green, the knuckles,calipers,u-blots,diff graud,3rd member,and steering rods will be green the rest black.it's gonna be sick
__________________
#62 (permalink) |
sick, the green looks good
__________________
1995 Toyota 4Runner
Cruiser Coils, Bj Spacers, Aisin Manual Hubs, 4crawler Panhard Drop Bracket, Extended Rear Brake Line, Skyjacker Shocks, custom LSPV Bracket, 15x8 Cragar Soft 8's, 33x12.50x15 Mud King XT's, Marlin Crawler Rear Bumper |
#63 (permalink) |
5:29s and instaul kit will be ordered firday(payday
__________________
#64 (permalink) |
here's an update:
so i've been busy this past month or 2...between work(which gets very busy in new england winter time working at a body shop,pulling like 50hr weeks) and building my axle...anyways here's the progress JB welded the knuckle balls smooth ![]() ![]() took apart and re-built the hubs ![]() ![]() got my gears and parts and set them up..the most part the gears done just gotta put a dial indicator on the them and check out the specs, once thats done i'll toruqe it all down and BAM! ![]() ![]() i also have the high steer parts painted and readt for instaul(these pics were before they got painted, the soda can is for size realitivity)the high steer is very beefy ![]() ![]() as of right now i just have to get then knuckle re-build and brake rotors, then the front axle will be done.so far it's looking like 3-4 months before the SAS goes down...can't wait!
__________________
#65 (permalink) |
Gear pattern on that 3rd is way too shallow from what I can see in that pic.
That is a broken pinion waiting to happen.
__________________
Scotty http://www.addictedoffroad.com/ 970-420-4198 Toyota Winch bumpers on SALE! Last edited by ScottyC; 03-22-2009 at 10:28 AM. |
#66 (permalink) | |
Quote:
__________________
#67 (permalink) |
ordering 4 of these..time to get rid of the bent old ones. no more wobbles for me
![]() http://www.4wheelparts.com/Wheels/Ro..._pn=PCW97-5883
__________________
#68 (permalink) |
cleaned up and primed my rear housing this weekend, i still need to weld on diff armor, and shock tabs, but i'm waiting for those to arrive. the UPS man is gonna know my house very well the next 3 months
__________________
#69 (permalink) |
i haven't updated this in a while, the axle is alomost done...awaiting a re-build kit from marlin(in the mail should have it by wesnday
)but here's what i have left to get before the axle goes in: -ford 57s for the rear -frt spring hanger kit -steering box mount -shocks+shock hoops -wheel spacers once the axle is in i can focus on getting the rear done -5:29 v6 gear set(yukons) -instaul kit -detriot locker -solid spacer -rear wheel bearings and seals -rear diff armor -shock tabs and shocks then once the rear is done i can get my frt d-shaft set-up and test it all out...can't wait looking like 2 months before the SAS. and then another month or so after that before i get 4wd back
__________________
#70 (permalink) |
got some wrok done the past 2 days....i'll just let these explain...
__________________
#71 (permalink) |
thats FUGGIN boss!!!
thats making me wanna pull my axle out from under my truck and give er a spit-shine too! love the colors. keep up the good work man
__________________
85 single cab longBOB 18'' gone, 4 inch peice-o-crap rancho lift, roger brown 3 inch body lift, 33x12.5x15 MT/R, flat black (apparently non responsive to radar guns =] ) 16 speaker sound system with 10 boston 6x9's, 2 phoenix gold tweeters,2 4x6 infinity's and 2 kicker 12's 2400w. PERFORMANCE MODS: heavy right foot, quick left foot |
#72 (permalink) |
the axle is now finished...just gotta start putting together my springs packs
__________________
#73 (permalink) |
spent this past week getting my front springs made...it's a RUF pack made from 86+88 pick up springs.here they are mocked up. i'm painting them with POR15, putting them together, then paint them with rustolum.(painted them with rustoluem is key becuase POR15 should be topcaoted, not left bear.)
![]() these are some really cool spring claps i found at a local spring shop(all they do is leaf and coils springs,and torsion bars). they call them "quick claps" they come in a varity of sizes and cost about $1 ea. to put them on all you do is c-clamp the spring pack put them together as shown and bend the tabs over. ![]() now i just gotta order up some ploy bushings...
__________________
#74 (permalink) |
damn dude, i just read up through the whole thread and your doing a sick job. i was hoping you'd be done with the sas by the last page but i guess i'll have to wait. keep up the good work and attention to detail and your gonna have one of the most badass rigs on here. what are you doing for tires?
__________________
2000 4Runner Limited V6 Auto... 2wd =[[[ Sony GT510 head unit, Kenwood 1700 watt max mono amp, Two 12 inch Polk Subs in ported box, 3 farad capacitor, neons in front footwells Foglights on bottom of rear bumper Optima Yellowtop, Kc daylighters on front bumper Vortex muffler and Trueflow airfilter |
#75 (permalink) |
thanks man...i'm hoping to have SAS done by late next month or so. as fro tires i'm thinking 35x12.5x15, either the new BFG KM2 or MTRs.
__________________
| Tags |
| jb, runner, sfa, toyota, trick, weld |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 87 runner and 85 runner parting out | insane04 | The Classifieds GraveYard | 6 | 05-28-2008 10:15 PM |
| just got a 93 runner | damage_priest | 86-95 Trucks & 4Runners | 1 | 04-20-2007 05:26 PM |
| Solid Axle Runner and IFS Runner Decisions | GreeneHoosier | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 11-18-2005 09:14 AM |
| Towing 86 runner with 90+ runner?? | wimpywade94 | Offroad Tech | 4 | 08-21-2005 03:44 PM |
| 92-95 runner bumper work on 91 runner? | 914runner | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 05-25-2004 11:17 PM |
