My truck just died on the road
Old 02-29-2008, 12:31 PM
yotakid825's Avatar
I was driving down the road, pushed in the cutch and the rpms dropped and it stalled I managed to get it home. I could keep it from stalling by holding it like 800rpm and up. I need help!
Old 02-29-2008, 12:34 PM
zlathim's Avatar
Is the CEL on?
Old 02-29-2008, 01:03 PM
yotakid825's Avatar
I just went outside to start it, fired right up and idled fine(well as good as it was before)
I don't think the CEL was on when it was stalling
Old 02-29-2008, 01:15 PM
keithguts's Avatar
This might sound stupid, but perss on the clutch at an idle, and see what happends.
Old 02-29-2008, 01:17 PM
Allstar93088's Avatar
When is the funeral?
Old 02-29-2008, 01:32 PM
drew303's Avatar
help if we knew what kind of engine you had
this is more prone to the 22r's than 22re's ime. The carbs as they age can do this time to time for no apparent reason and nearly impossible to diagnos exactly. Humidity, fuel, temperature and how gunked up the carb is, all play a complicated role.
Old 02-29-2008, 01:48 PM
yotakid825's Avatar
oops, It's a 22re
Old 02-29-2008, 04:12 PM
Brenjen's Avatar
Check your distributor cap & rotor, they can do this too.
Old 03-01-2008, 05:58 PM
yotakid825's Avatar
today I took my truck down the road. when I left my driveway it was idling at 1100(cold), at the end my road(about a 1/2 mi) it was idling at 750 when I got back in my driveway it was trying to idle at like 200 then it stalled. I'm thinking this problem is fuel system related.
Old 03-01-2008, 07:27 PM
91Toyota's Avatar
could be...maybe a fuel filter or dying fuel pump...I would check elsewhere first. Mine starts fast...idles at 1500 right after start up then goes to about 2100 then gradually declines.
Old 03-02-2008, 06:21 PM
yotakid825's Avatar
Im guess it's the fuel filter because it runs great for a few min. then runs like crap. I'll let it sit for alittle while and then starts and runs fine, but again a few min. later it runs like crap
Old 03-02-2008, 06:24 PM
93Toyota PU's Avatar
Could be EGR related...
91toybeater
12-27-2015 07:46 PM
puffin04
07-10-2015 09:17 PM
ibayne
06-26-2015 06:30 AM
slider417
06-22-2015 10:18 AM
nrgetic99
07-10-2002 07:39 AM
Quick Reply: My truck just died on the road
