Is my speedo off?
Is my speedo off?
so there's my line up! 1987 turbo 4 runner! swapped to manual not done by me!
had a 430 in the rear! but was 410 in front so i fixxed that now its back to factory 410's! like engine bay tag says!
I'm running 30x9.50 tires on 15's
and has digital dash!
At 2000 RPM in 5th i'm doing about 49 to 51mph!
At 3000 RPM in 5th i'm doing 69 to 70 mph!
does that sound right
of do i have the wrong speedo gear?
here is another gear/speed calc http://www.grimmjeeper.com/gears.html
Option#1: Grab your GPS{or someone's} and go for a spin. Mine is accurate to within 1% in the speed setting{that better than most stock speedos}.
Option#2: For you country people , 60mph takes you 1 mile in 1 min.
Lots/most of the "grid" roads are layed out in the mile system. Should be able to tell how close your speedo is.
oh its the r151e out of the turbo truck my buddy parted out dues to super bad rust that where the trans in from i would guess the same on the transfer case but i'll have to ask!
well it would be the R151F (not the E)
ratios are:
First Gear: 4.313:1
Second Gear: 2.330:1
Third Gear: 1.436:1
Fourth Gear: 1.00:1
Fifth Gear: 0.838:1
T case ratio is:
2HI and 4HI: 1:1
4LO: 2.28:1
ratios are:
First Gear: 4.313:1
Third Gear: 1.436:1
Fourth Gear: 1.00:1
Fifth Gear: 0.838:1
T case ratio is:
2HI and 4HI: 1:1
4LO: 2.28:1
or you could just follow a buddy or family member and pace them..... Mine's been off for years. I just jot down the speeds I'm showing to what they really are and go off by that. Someday I'll have a gps to make it a bit easier.
I recently got some 5.29's in my v6 thirds and I am running 37" MTR's and my speedo is still correct. I noticed that when I was running 31's and 4.10's it was correct as well.
sounds like its correct to me. Since all turbo trucks whether they are auto or manual use stock 4.10 gearing, the speedo gear shouldn't matter. Get out on the freeway and try using the mile markers to figure it out. Keep it at 60mph between the markers, and as suggested above it should take you 1 minute per mile. Any large variance and you know you have a problem with your speedo or gear.
charlie_fong
09-27-2015 10:06 PM
travisamorgan
09-02-2015 01:00 PM
94ofCanada
08-14-2015 06:37 AM
Pedalpwr27
08-13-2015 06:37 AM
