My Saggy Rear
My Saggy Rear
Ive been browsing the forum for a while and just discovered what all the fuss is about the "ZUK mod"...after looking at some before and after pictures I discovered that my truck (ive only had it since january) is pretty saggy...I thought the ride was just harsh...
1986 4x4 regular cab turbo 5spd.
A better look at the sag
There is nothing in the tool box lol
I guess this is what happens to 25 year old springs with 300k miles on em.
The question is... New leafs or ZUK mod? The truck is my daily driver...I put about 60 miles on it every day...and its not really a highway...
I dont ever plan on running bigger tires than the 31's that are n it right now.
I'm intrigued by a 1.5" lift but dont think I'd ever go more.
Im looking for reliability and driveability. The truck will see off road use about 3-4 times a year.
Whaddya guys think?
Whaddya guys think?
I had some sag in my 87, and did an add-a-leaf. I'm pretty happy with it, I think it looks better, and carries a trailer better. Maybe the ride is a little worse, but eh, it wasn't that good before. I didn't use shims, and maybe that's why my last ujoints only lasted a year.
Something I thought about was doing lift shackles. But there are more knowledgeable folk than me about springs and leafs (or is it leaves).
Or you could do like I did on my 2WD. The rear end was noticeably lower than the front, but not too bad, about like yours. I loosened the torsion bars up front and lowered the front end about an inch, so that the truck is perfectly level now. Didn't cost a cent either.
One additional thing I had to do though was chop off about an inch from my rubber bump stops up front, because after lowering I only had about 3/4th's of an inch of travel up front and was bottoming out constantly.
No problems so far, after six months and probably 10,000 miles. I figure I probably get slightly better gas mileage too. I originally wanted to do a Zuk mod, but those don't work on a 2WD, so I did this instead.
Are your shocks in decent shape" That might help your rough ride.
Ya the shocks are in good condition...the problem is the rear springs are basically flat...so they're not doing their job at all....
It seems people are directing me to replace the springs...
What are some replacement springs that are reasonably priced and offer good ride quality? Maybe something that I could do an 1.5" BJ spacer and make it all look good?
There's about a trillion threads on lifts but I basically was stock height or maybe an inch taller and something that's good for a daily...
I'm still tempted by the ZUK...
Let me jump in here for a second.
With new leaf springs you're going to have to deal with sagging again in the future. With the ZUK mod you will never ever have sag again. The coils take a lot more load than a leaf and make the ride better than it was factory. You could go with some 12" 125lb coils and I think it'd be just about level. You could do some 14" 125lb coils and then add 1.5" BJ spacers up front for some lift. Maybe even some 12" 100lb coils since you don't seem to haul a lot in the bed.
ZUK mod- about 60$ for coils if you don't lift the front.
New Leaves- No idea but I'd bet its more than 60$ and it'll sag again over time.
Edit: That truck is freaking beautiful. Just wanted to add that.
There's a reason why Toyota engineers switched to coil springs on the later model 4runners and 80 series Land Cruisers. Think about it....
I had the same problem and I got new leafs and I'm totally happy with it. can't speak to the zuk mod. I suppose new leafs will sag over time, but if your truck goes another 300k or 20 years or whatever saggy leafs will probably be the last thing on your mind.
Location: Downtown Heckronto, Ontario, Soviet Canuckistan
1 Post
In the end, new packs left a bad taste with me.....seems some packs never sagged and other did it very fast. Case in point here....
http://www.gearinstalls.com/scottcoil.htm
All it took was 1 Rubicon Express TJ coil to fix Scotty's sag....actually gave him the 3.5" of additional lift that he wanted.....maintained his nice cushy soft ride and no loss of his excellent articulation. It's been 5 or 6 years now and no noticeable change in lift. So, now when he goes off-road and flexes it out thru the deep ruts, people see the strange center coil and it turns into quite the conversational piece. Seems that the single coil took enough of the weight off the leafpack to make the leafpacks last as intended.
Coils have the easy life and only do 1 thing...they support the weight. Leafpacks do that and they also have to locate the axle front/rear and side to side, too. Is that one of the reasons why they might sag?....maybe. Or, is it because of a hit and miss thing if you're getting a quality set of packs that have good quality metal, proper heat treatment and possibly shot peening.
