My right side lower control arm is rusted thru, how do i replace?
Old 11-08-2014, 12:54 PM
maddevildog's Avatar
Hi guys,
The right side lower control arm on my 1995 4 Runner is shot, is this a big job to replace it? Anyone have tips or instructions on how to do this, videos and pics are cool too if they are out there.
Thanks,
DJ
Old 11-08-2014, 01:57 PM
Robert m's Avatar
HOLY ˟˟˟˟!
Normally they are pretty easy and you just have to remove the bolts and balljoint but with that much rust, you're probably going to have a battle on your hands
Old 11-08-2014, 02:07 PM
The truck runs awesome, its just the damn rust. I just blew a break line the other day and thats when we found this..........
Old 11-08-2014, 02:21 PM
wyoming9's Avatar
Red face
You really need to get under there and do a major inspection!!
If the lower control arm is rusted what else is in the same shape.
I would hope your redoing all the brake and fuel lines.
What I want to know is how did you let it get so bad before catching it??
Maybe your a Jiffy Lube type of person.
Old 11-08-2014, 02:28 PM
Everything else is still pretty decent except this, everything was looked at when the brake line was redone today. The truck does not run much, mostly during hunting season and a few times when i take my 14' boat to the lake. Not sure of the point your making about being a Jiffy Lube person though. I don't get off working on trucks and cars, I drive them.
Old 11-08-2014, 04:02 PM
Hugh_Mann's Avatar
Yeesh, that's ugly. I'd do a thorough frame inspection with that sort of rust.
Removing the control arm isn't difficult, just the two arm to frame bolts and the 4 lower balljoint bolts I believe. You may need a torch though
Old 11-08-2014, 04:09 PM
Frame checked out good, this is the biggest issue it has. Granted, there is rust but nothing that is to this point. I am the second owner, the truck has 145K on it. I have had it 3 years and only put about 1500 miles on it.
Old 11-10-2014, 10:18 AM
Innocent Fool's Avatar
In theory it's not that hard to replace but I found that the bolts that attach the arm to the frame were rusted and seized inside the control arm bushings. Could get the nut off but couldn't pound the bolts out. Ended up having to cut the bolts to drop the arm out
Parts I needed were another control arm 2 control arm bushings and 2 new bolts with nuts.
The two bolts also control the camber & caster so you will need an alignment when you are done.
voiddweller
19
05-02-2016 09:10 PM
Niameyrider
06-25-2015 05:50 AM
ranma21
06-22-2015 11:55 AM
2wdtundra
06-17-2015 01:41 AM
be_deviler
07-01-2002 05:27 PM
Quick Reply: My right side lower control arm is rusted thru, how do i replace?
