is my fuel pump going out? some kind of sensor?
Old 12-21-2008, 02:46 PM
mattaway's Avatar
when i'm offroad the motor wants to cut out, like it wants to stall but doesn't. it never acts like that on the street.
today after coming back from the mudhole it stalled out on me on the street and wouldn't crank up for a couple minutes, then when i got it started it acted like it was running on 2 or 3 cylinders and as soon as i'd touch the gas it'd die.
after turning it over for a good 5 minutes it started up and drove me home fine.
a couple times on the way home the check engine light flashed on for maybe 1/4 mile and flashed back off.
Old 12-21-2008, 02:54 PM
toyota4x4907's Avatar
some sensor is probably loose. check the plug on the AFM to make sure its on there well and is clean. Clean the AFM.
pull the codes and post them up here.
Did you go through any water?
Old 12-21-2008, 02:59 PM
mattaway's Avatar
AFM??
i went through a little bit of water, but it was acting weird before the water.
by the way it only wants to cut out when going forward, it's fine in reverse
Old 12-21-2008, 03:02 PM
scuba's Avatar
We need more info on your vehicle...year model...engine ?!?
The afm is the thing ontop of the air box...
Old 12-21-2008, 03:06 PM
mattaway's Avatar
it's a 92 pickup dx 22re 5 speed
what does AFM stand for?
Old 12-21-2008, 03:10 PM
afm= Air Flow Meter
Like scoobie-doo said, its on top of the air filter box/housing. It measures the amount and temperature of air entering the intake tube, sends that info to the ECU, which sends calculations to the fuel pump, which sends the appropriate amount of fuel......
Someone correct me if I explained it wrong....
Pull the CODES!!! POST 'EM UP!!!
Old 12-21-2008, 03:15 PM
scuba's Avatar
No, you explained that right 907...
Is your Check engine light on...?
If not you might have stored codes..
here...
http://www.4crawler.com/4x4/CheapTri...CheckConnector
sandyota
02-04-2021 11:16 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Fundy Rider
07-16-2015 01:35 AM
Tyler Cunningham
07-11-2015 10:18 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: is my fuel pump going out? some kind of sensor?
