my 1986 extra cab pick up is slow!!
my engine is 22R Carburetor and i had K&N filter
and bone stock parts. and it was slow!
wats make my truck to be fast on up hill?
hmmm im thinkin about after market exhausts
that is CARB so it can passed smog.
and i lived in California...its due to smog emissions law
so i dont want any tickets from cops!
Dude it's a 22R.. that thing is all of 90HP. What do you expect? If you want to go fast uphill rip the engine out and put something else in it. There's no replacement for displacement. Is English your first language????
well first off...get a header put on there...and if you dont live in a state where u have to pass smog..get rid of the cat...make sure your timing is set right..make sure the carb is cleaned..might even want to rebuild it..get an exhaust of your choice..dont go over 2.25in in diameter..might take your egr pipe off and make sure its not clogged..
what size tires do you have?
*EDIT* and yes..i agree with UKmyers its not a speed demon of a truck..but mine with 31" swampers and all stock except for the header and turbo muffler would pull 80 up hill........right before it spun the #2 rod bearing..................
It's a 22r get used to it or get rid of it. You can spend thousands on aftermarket parts but its still a gutless 22r. I would add a weber carb cause the stocker sucks but your going to experience minimal power increase with any part
06-01-2021 01:51 PM
nanhodges2733
05-29-2020 03:28 PM
