mx6 shock setting advice ?
Old 01-23-2014, 02:59 AM
clok's Avatar
i recently had the pro-comp mx6 6 way adj. shocks installed on my runner and was wondering should i set the front one notch higher then the rear due to the extra weight in the front from the motor ? or should i set all four corners the same ? also if i ever hit a trail should i set the shocks to the stiffest setting ? any advice on setting these shocks would be great .
i have them set at 3 all the way around and feels pretty good not to soft or stiff thinking about trying to set the fronts to 4 and leaving the rears at 3? , i know if i put weight in the rear i should stiffin up the rear more.
88sasturbotoy
08-11-2015 01:56 AM
SMOD
07-27-2015 01:45 PM
MTLroadierunner
07-20-2015 03:07 PM
Massmayhem247
07-18-2015 05:46 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: mx6 shock setting advice ?
