MPG + or - w/ Engnbldrs 261C
Wish I could tell ya. Never drove the truck before I rebuit it. Dead when I got it. I,m running the same cam with thorly headers at 30 over as soon as it,s good and broken in I'll check the mileage. Getting around 17 or so now with 31's, auto, and stock gears on the highway @ 60 -75 mph. Plus it's running rich. can't figure out why yet. Subscibing I,m interested too.
Jim
Jim
well i have a question is the 261 much bigger than stock? also where did u see best improvement in powerband? and does it have a lopy idle or it if fairly smooth?
I put in the 261c when the engine and head were rebuilt (stock rebuild) and I have not noticed a difference in mileage. Still getting 20-22mpg on 33's, 4.10 gears with a 5 speed, mostly highway miles.
how on earth are you getting 20-22 with 33s and 4.10s? TELL ME YOU SECRETS!
When I bought the truck with 31X10.50 BFG's it was getting 22mpg when I factored in 10% for the bigger tires. Now I factor in 20% for the 33's and I'm still getting the same, I'm suprised too. I have stock exhaust with a magna flow 2" CAT, K&N drop in filter, and the cam, that's it. Elevation here is 5500 ft.
I am also curious exactly what needs to be done to install the cam? What needs to be removed? Can you merely undo the stock cam, hold the timing chain sprocket in place with a piece of dowel and then slide the new one into place? Do tell.
To remove the cam the headbolts have to be removed. People say they have successfully removed them and changed the cam without head gasket problems...but I wouldn't try it. But yes, cam sprocket comes off with the chain, cam bearing caps off, old cam out, new cam it, bearing caps on, head bolts back on.
I'll throw in my 2cents as well. My headgasket was very slightly leaking at 175k, so I pulled the head off to re-do it and used the excuse to throw a StreetRV head and 261C cam on there (truck in sig). Factory tires and gearing. I haven't really seen a noticeable difference in mileage. I get anywhere from 22-24 Hwy and 16-19 City/country roads. I've gotten as bad as 12 (1 mile commute in cold) and as good as 27 (all hwy, tailwind). I do have a 2.25 catback, but otherwise nothing majorly different.
RustBucket
08-10-2023 05:05 AM
Longbed 90
03-11-2019 12:38 PM
Jaden84
10-23-2011 07:14 PM
