Motor rev
Old 12-18-2013, 07:43 AM
nicks86's Avatar
Motor rev
Hey guys need some help can't figure out y my 86 pickup 22re motor reeves up and down when I come to a light and apply brake any ideas? Only does it when at idle and brake is applied
Old 12-18-2013, 08:03 AM
bbrideau's Avatar
check for vaccuum leaks. when you hit the brakes the booster demands vacuum from the motor to assist in braking. a leak in the line could cause a surge in the idle or if the diaphragm. Problem could also be in the booster as well if there is a crack in the booster or in the diaphragm it causes a leak in the system as well
Old 12-18-2013, 08:07 AM
Yamiryder's Avatar
yeah, most likely a booster problem. Mine did that once.
Old 12-18-2013, 07:40 PM
YotaWoRx's Avatar
Ur idle should be at 750. Adjust it to do that
Old 12-19-2013, 07:16 PM
nicks86's Avatar
thanks guys great advice gonna check those things this weekend
okamikai
04-30-2018 10:19 PM
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
Flossy
08-05-2015 05:14 PM
Dakotaneu
07-27-2015 12:03 AM
Quick Reply: Motor rev
