Most Common Engine Oil Leaks ?
Old 10-10-2009, 08:01 AM
skinnadoor's Avatar
I have a small leak, more like a seep. Seems to be collecting very slowly and there is a small drip on the front drive shaft. Above the shaft it looks pretty wet on the back side of the engine, however my engine oil level is fine and there are no drip stains on the concreate.
So i thought this thread could help myself and others if 22RE owners could list off the typical and not so typical spots where engine oil starts seeping out from on the 22RE engine.
Thoughts ?
Old 10-10-2009, 08:21 AM
yotaman90's Avatar
The valve cover gasket and the half-moon gaskets in the head seem to be common leaks
Old 10-10-2009, 08:41 AM
yoterr's Avatar
x 2 ^^^
Old 10-10-2009, 08:57 AM
Teuf's Avatar
Mine leaks a bit from oil pump seal, prob a groove worn on shaft. There is a fix (sleave), but its so minor i'll do that when i change out my timing chain some year.
Old 10-10-2009, 02:11 PM
Murakami's Avatar
and the oil pan.
Old 10-10-2009, 03:20 PM
yotaman90's Avatar
And don't forget the rear main seal
Old 10-10-2009, 04:35 PM
TNRabbit's Avatar
Most of the valve cover leaks are due to not bad gaskets, but failure to put FIPG in the corners where the gasket makes a 90 degree bend. The FSM shows specifically where to place the SMALL dabs of FIPG to prevent this.
Old 10-10-2009, 04:37 PM
turboboost's Avatar
Pretty much everywhere on the engine is common to leak.
Old 10-10-2009, 05:04 PM
Blk63vette's Avatar
I have a leak there too...Someday I will fix it..
Old 10-10-2009, 05:33 PM
highridinyota's Avatar
a toyota wouldnt run if it didnt leak somewhere
Old 10-10-2009, 07:05 PM
Teuf's Avatar
Oil leaks, Keeps the dust down on my / ooops former dirt road.
Old 10-10-2009, 07:08 PM
MattGGT's Avatar
That's the best sum up.
Old 10-10-2009, 07:32 PM
flyingbrass's Avatar
Hey now, this isn't a Jeep forum.
Valve cover gasket itself
The half moon seals at both ends of the head (use RTV underneath them and a small dab on top at each corner -- the FSM explains this)
Front crank pulley seal
Oil pump o-ring
Distributor o-ring
Rear main seal
Oil pan to block junction
I'm probably missing something, but those should be in roughly descending order of frequency, give or take.
Old 10-10-2009, 08:02 PM
TNRabbit's Avatar
Mine leaks NOWHERE....except the amount of fuel passing through the engine & out the exhaust~
Old 10-10-2009, 08:16 PM
abecedarian's Avatar
sorry for the 'abridged' edition but I read the post and was left with...
... basically ...
Originally Posted by skinnadoor
I have a small leak...
>snip<
... and there are no drip stains on the concreate.
Thoughts ?
Given that, I'd say drive it forever and don't top up any fluids until you can figure out which fluid it is that's leaking.
Hypoid doesn't smell like brake fluid doesn't smell like engine oil doesn't smell like engine coolant doesn't smell like auto-trans fluid (used in the power steering system) doesn't smell like gasoline doesn't smell like fan-clutch oil.
Old 10-10-2009, 08:17 PM
I have a small leak... Thoughts ?
I have a small thought... Pictures?
Old 10-10-2009, 11:34 PM
snwbrdr852's Avatar
Mine's a little leaky too. I haven't had a chance to try and pinpoint it yet though. I don't want to do any hijacking here, but since we're talking about oil leaks... Does anybody have any feedback, good or bad, on any of the oil stop-leak fluids?
Old 10-11-2009, 12:18 AM
pruney81's Avatar
don't use oil stop leak fluids, if anything just use a thicker oil like 10W40 or 20W50
Old 10-11-2009, 07:10 AM
90-3vzeslug's Avatar
x2 pruney!
Old 10-11-2009, 03:36 PM
annoyingrob's Avatar
Grab a front main seal from an old 22R (pre 85). It's a different depth, so it will sit on a different part of the crank, allowing it to seal without having to sleeve the groove. I put an 85+ seal on my 83 motor because of the groove worn in the crank and it worked great. Still running without any leaks.
bigjstang
08-25-2021 12:41 AM
Yota.Jay
07-23-2015 08:08 PM
Avenged
07-09-2015 07:55 AM
toyoda8488
07-05-2015 10:18 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Most Common Engine Oil Leaks ?
