More fuel leaks
More fuel leaks
so i noticed the other day a lite fuel smell around my truck i looked at the fuel rail and injectors, where i had a lot o leaks recently. everything was dry and i didn't smell it in the engine bay so i thought i was being paranoid again. any way i walk near my truck and noticed a definite fuel smell i traced it down to some where on top of the tank it's leaking and dripping down. so is there any accses under the carpet or do i need to drop the tank? is this a common thing? And how do i replace fuel line is it like brake line where you just patch a piece in with flared compression fittings.
Check your filler pipe. Mine is leaking too right above the tank. I havent done it yet, but i dont think it will be that bad to replace. Hopefully wont even have to drop the tank. But I'm not positive, has anyone done this?
mine was leaking park on a hill with a full tank i don't know where it came from yet i noticed it dripping off of the bash plate after sitting for a day so there's no way there should have been pressure left in the line if the line leaking. So i'm hopeing it's just the filler neck
Avenged
07-09-2015 07:55 AM
