YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-07-2008, 10:34 PM   #1 (permalink)
Melted distributor cap and rotor
I've got a 90 3.0 and three times now I have had my distributor cap and rotor melt on me. I know the compression is bad on the #5 cylinder, and I am idling very rough, either heads or valves, no smoke in exhaust though, and no burning oil. Anyone ever hear of or see something like that?
Thanks
psycho2005 is offline
Sponsored Links
To remove this ad, register today!
Old 05-08-2008, 05:43 AM   #2 (permalink)
Noltz's Avatar
Bad compression should have no effect on your cap/rotor. If you're running really rich, your exhaust manifold might be getting too hot. would explain your rough running too.
Definitely a heat issue. Get your motor sorted and go from there. Short term fix would be to fab a heat shield to protect your distributor.
__________________
•-Noltz-•
'95 4Runner SR5, mostly Stock, w/OBA & AirLifts. His.
'97 4Runner Limited, Stock w/E-Locker & 285s. Hers.
'91 4Runner, 3" BL, 35's & 8000# Winch.
SOLD
Noltz is offline
Old 05-08-2008, 05:47 AM   #3 (permalink)
toytech76's Avatar
get it fixed. You arnt doing you or your motor any favors by running it like that
__________________
97 Runner. 3" revtek front with 1/2 added spacer, front 97 LC coils and shocks in the rear, 33x12.5/15 Pro Comp mud terrains, 15x8 Pro Comp 1069 alloys, 00 runner headlites, clear corners and bumper lenses, 00 runner airbox/MAF conversion, Reverse indiglo gauges, 5000K HID's, LC hood struts, Magnaflow exhaust, custom grill insert, hella driving lights converted into headlight highbeams, retrofitted avalon homelink sunvisor.
toytech76 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Distributor cap MAXIMUS1968 86-95 Trucks & 4Runners 3 12-18-2007 08:02 PM
22RE Rotor and Distributor Cap 90RunnerRed 86-95 Trucks & 4Runners 4 03-07-2007 07:05 PM
Distributor Cap Rotor Question idealconcepts General Electrical & Lighting Related Topics 3 11-07-2006 11:14 AM
What distributor cap and rotor would you ctcost 95.5-2004 Tacomas & 96-2002 4Runners 4 10-13-2004 02:03 PM
second rotor cap? Babypig 95.5-2004 Tacomas & 96-2002 4Runners 1 01-05-2004 04:23 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
