melted alternature fuse Box
Old 05-30-2015, 12:16 PM
JPolk's Avatar
I was going to work this morning and i started to smell some plastic burning but it quickly went away. After that i checked the fuse box and where the alt fuse is was all melted! The fuse for the alt wasnt event broken everything else around it melted, the brake light and battery lights are on! anyone know what happen. its a 1994 Totota Pickup 4x4
Attached Thumbnails melted alternature fuse Box-1433016799954-1643940648.jpg   melted alternature fuse Box-1433016877770-559671606.jpg   melted alternature fuse Box-1433016893115837261171.jpg
Old 05-30-2015, 01:20 PM
rworegon's Avatar
My guess....a loose connection generating heat via resistance possibly.
Old 05-30-2015, 01:43 PM
wyoming9's Avatar
Red face
What he said kinda
A loose connection in any electrical circuit will get real hot in very little time
Was the connection loose when you removed it
Old 05-30-2015, 02:12 PM
JPolk's Avatar
they were tight on there as far as i know i havent messed with the wiring that much untill now. i know for the longest time when i turned my blinkers on or when i went accelerated and slowed down everything would go hyewire. i just rebuilt my engine maybe something is loose somewhere
Old 05-30-2015, 05:28 PM
Robert m's Avatar
This sort of thing happened to my truck a few years back. Check the main alt charge wire for any melted spots. https://www.yotatech.com/forums/f131/lights-out-266855/
Old 05-30-2015, 05:37 PM
JPolk's Avatar
so i think i found the problem. while back i bought a new alternator from O,Reillys and turns out that they sold me the wrong alternator! It was pushing 70amps instead of 60amps and it fried some of my electrical componiates! Im pretty pissed at O'reillys right now! It was an alternator for an automatic in instead of a manual.
Old 05-30-2015, 05:43 PM
osv
osv's Avatar
the alternator on my 22re puts out 140 amps max, and it hasn't fried anything.
Old 05-30-2015, 05:47 PM
JPolk's Avatar
I guess it was the type of alternator because it was recently bought and it just fried yesterday
Old 05-30-2015, 06:30 PM
skypilot's Avatar
I tend to think it was corrosion and under sized wires. I have a 4ga wire from the alternator to the battery just to help out. The wires are pretty darn small. You would think using a larger gauge of wire would kill them.
Old 05-30-2015, 06:49 PM
RAD4Runner's Avatar
Concur with rworegon.
Higher amp alternator will not cause it. However an alternator with shorts (Auto-parts store sell bad alternators once in while, correct?) could.
Disconnect battery cables.
Disconnect "B" wire from aternator screw post. Measure resistance from screw post to ground. try to rotate alternator if possible. resistance should read in meg-ohms. Lower than that means shorted winding or rectifier.
Cheers!
fountain
09-19-2015 08:16 PM
sniper34639
08-31-2015 07:56 AM
bvleonov
08-22-2015 11:39 PM
Mrhoadley
08-04-2015 06:08 PM
rushw
07-18-2015 01:46 PM
Quick Reply: melted alternature fuse Box
