Max Size Wheels & Tires on Stock 93 4x4 Pickup? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-08-2006, 10:26 AM   #1 (permalink)
C5VetteLS1's Avatar
Hello All, I'd like to upgrade my tires and wheels to a larger size. My truck is a 1993 Ext Cab, 3.0, 4x4, 5-Speed, Bone Stock with no lift. I'd like to lift it, but that's out of the question due to an occational handicap with my knees. So my question is, what are the largest wheels and tires that I can put on this truck without having to lift the truck? I relize that higher profile tires will lift it a bit, and that's ok.
Thanks in advance for any advice
Richard
__________________
1993 Ext. Cab Long Bed 3.0 Liter 5-Speed SR5 Pickup
C5VetteLS1 is offline
Old 05-08-2006, 02:35 PM   #2 (permalink)
BeaterToyota's Avatar
This subject has been beaten to death. Try searching a little and you'll find tons of info on this site. This has already been discussed 1000 times.
I am feeling a bit helpful, so here you go:
31x10.50, no problem.
32x10.50 (what I used to have), no problem.
32x11.50, probably need to crank the torsion bars and/or hammer the body seam at the back side of the fenders.
33x10.50, same as 32x11.50.
33x12.50, can be done, but you'll have a lot of cutting/hammering to do to fit in the front.
BeaterToyota is offline
Old 05-08-2006, 03:23 PM   #3 (permalink)
91_4x4runner's Avatar
Send a message via AIM to 91_4x4runner
*nods* Search should yield you with a ton of results.
__________________
~Eric
1991 4Runner 3.0L 4x4 Black, 31" Michelin M/S tires, OME-901's
1992 Lexus SC400 4.0 V8, Green with Tan interior (donor) (PM me for parts)
Near Future: FI 1UZ swap. (June)
Far Future mods: F/R Lockers, SAS, 35's.
UZswap.com - A discussion forum dedicated specifically to swapping UZ engines into Toyota trucks and 4Runners
91_4x4runner is offline
Old 05-08-2006, 04:20 PM   #4 (permalink)
Toyofast's Avatar
You forgot 35x10.5 on stock 15x7's fit with very minor trimming of pinch weld are rear of fenders
Toyofast is offline
Old 05-08-2006, 04:24 PM   #5 (permalink)
brandontrek's Avatar
32's are the nicest look IMO...
__________________
2003 Buell Firebolt
Trek STP400
Sneakers
brandontrek is offline
Old 05-08-2006, 04:47 PM   #6 (permalink)
Staff
rocket's Avatar
Don't forget to regear when you upgrade tire size. Stick with 15" rims! You can get black steelies for about $50 each.
What size tires do you have now? Theres plenty of options with a 31x10.50 plus you wont have to regear. If you want bigger, then look at a 33x10.50 or 32x11.50
__________________
'96-'02
gone: '92
rocket is offline
Old 05-08-2006, 06:38 PM   #7 (permalink)
AUYota's Avatar
Send a message via AIM to AUYota
From what I've read on this, the 33 10.50 is the best deal for what you get out of it.
More clearance, on-road ride quality etc. I've heard that the 32 11.50 are a bit rough, and I'd rather have the extra inch in clearance from the 33.
Lastly, if you have a relatively new set of rear springs, these will go on no problem.
AUYota is offline
Old 05-08-2006, 11:10 PM   #8 (permalink)
C5VetteLS1's Avatar
Many thanks I wasn't being lazy by not searching, in fact I did search on wheels because I expected to be told to do a search. Problem was the right key words to use. I found a lot of info on tires and wheels, but couldn't find a thread for Max Sized for Stock Lift. So thanks again for your input.
Richard
__________________
Old 05-08-2006, 11:16 PM   #9 (permalink)
C5VetteLS1's Avatar
Quote:
Now that's an awesome set up ... got a feeling those wheels are out of my budget though. I'll do a yahoo search to find out.
__________________
Old 05-08-2006, 11:22 PM   #10 (permalink)
C5VetteLS1's Avatar
I currently have stock size wheels and tires. I believe the tires are 30x7 on 15" wheels. Thanks for bringing up the issue of regearing ... I don't want to do that. I'm sure 31x10.5 would be fine for me. I'll need to add fender flairs with these correct?
__________________
Old 05-08-2006, 11:46 PM   #11 (permalink)
91ToyTrck's Avatar
Send a message via AIM to 91ToyTrck
I'm personally buying 33x10.50 BFG MTs with a stock suspension. I might add a 1" body lift and a drivetrain lift instead of an all out suspension lift. I just can't wait to have a good set of rims/tires on my truck. Good Luck !
__________________
'97 Jeep Grand Cherokee *DD till I can afford my '05+ Tacoma*
91ToyTrck is offline
Old 05-09-2006, 02:02 AM   #12 (permalink)
ovrrdrive's Avatar
Here's a pic of mine with 32x11.50 Dueler AT's... I have a 3" body lift and cranked on the torsion bars a little.
__________________
'95 xcab - SOLD
'03 4runner V8 SR5 completely stock
ovrrdrive is offline
Tags
321150, 331050, cherokee
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
WANTED: Toyota wheels for 1984 or 1985 4x4 pickup stock steel white Rozzi The Classifieds GraveYard 1 06-01-2008 07:09 AM
Max tire size on Enkei 15" runner wheels chimmike 86-95 Trucks & 4Runners 9 01-26-2007 11:01 AM
bodylift+big rims+big tires= max size?? dexter 95.5-2004 Tacomas & 96-2002 4Runners 20 12-07-2005 05:54 PM
max tire size for 03 sequoia 4x4 w/out lift gasoel 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 6 08-16-2004 10:36 PM
2009 InternetBrands, Inc.
