Mass load of parts replaced, still no start
Old 10-18-2011, 04:21 PM
02/89yota's Avatar
After replacing almost EVERY damn part in the fuel system, then replacing, the plugs, wires, cap rotor and TPS, the damn thing wont start!
Can anyone lead me as to what would cause this POS to do this?!
Old 10-18-2011, 04:23 PM
Adk_Yota's Avatar
What engine are we talking about? Does it crank? Do you have spark? How about fuel?
Old 10-18-2011, 05:10 PM
02/89yota's Avatar
22re, fuel is there so is spark and compression
Old 10-18-2011, 05:12 PM
xxxtreme22r's Avatar
What were you doing before it wouldn't start?
Old 10-18-2011, 05:51 PM
02/89yota's Avatar
Cruisin down the road at 35 then she sputtered and died
Old 10-19-2011, 12:42 AM
TNRabbit's Avatar
Check for ECU codes.
Then check the 80-amp underhood fuse.
Old 10-19-2011, 01:02 AM
02/89yota's Avatar
Codes are 51 and 71, amd I have thw see through top big fuses amd the 80 is unbroken but kinda purple
Old 10-19-2011, 03:55 AM
TNRabbit's Avatar
You need the FSM. You can get it here: http://www.ncttora.com/fsm/
Codes 51 and 71 are switch sensor and egr system. 71- two things can cause that. the engine reaches operating temp and the ECU tries to open the EGR valve but the temp sensor on the EGR valve isn't up to the right temp, or the engine reaches operating temp and the ECU tries to open the EGR valve but the temp sensor on the EGR valve isn't up to the right temp. the first one could be a faulty temp sensor on the EGR valve and the second one could be a restricted EGR passage.
51 is a "switch signal" meaning, IIRC, the TPS is not signalling IDL to the ECU, the clutch switch was on or the a/c was on.
Here are the common codes for Toyota vehicles 1988-95:
Code 11 Momentary interruption in power supply to ECU (electronic control unit or computer) up to 1991
Code 12 Engine revolution signal missing
Code 13 Rpm signal to ecu missing above 1000 rpm
Code 14 Igniter signal to ecu missing
Code 16 A/T control signal missing from ecu
Code 21 Main oxygen sensor signal fault
Code 22 Water temperature sensor circuit fault
Code 23 and 24 Intake air temperature signal fault
Code 25 Air/fuel ratio LEAN
Code 26 Air/fuel ratio RICH
Code 27 Sub-oxygen sensor signal or heater circuit fault
Code 28 No.2 oxygen sensor/heater signal fault
Code 31 and 32 Air flow meter circuit or Vacuum sensor signal fault
Code 34 and 36 Turbo-charging pressure signal fault
Code 35 Altitude compensation sensor signal fault
Code 41 Throttle position circuit fault
Code 42 Vehicle speed sensor circuit
Code 43 No starter signal to the ecu
Code 51 AC signal on; DL contact off (in trany shifter with diagnostic connector jumped)
Code 52, 53 and 55 Knock sensor fault
Code 71 EGR system malfunction
Code 72 Fuel cut solenoid signal fault
Code 78 Fuel pump control signal fault
Code 81, 83, 84 and 85 TCM communication fault
Old 10-19-2011, 05:07 AM
thanks for that list TNR it's a little different then the one I was looking at for " OBD I " vehicles.
Old 10-19-2011, 05:46 AM
toyotaPmanager's Avatar
got fuel, spark,compression,air....only leaves timing. have you checked it?
Old 10-19-2011, 08:38 AM
02/89yota's Avatar
The TPS sensor was replaced yesterday aswell....
Old 10-19-2011, 08:39 AM
Just because it's a new TPS, doesn't mean it's adjusted properly.
Also, I have learned the hard way just because you replace an electrical part on a vehicle doesn't mean the new one you got was good from the get go.
Old 10-19-2011, 08:46 AM
02/89yota's Avatar
Thats true, how can I test it and how hard is it to adjust to spec
Old 10-19-2011, 08:47 AM
Procedures are listed in the fsm.
Old 10-19-2011, 08:48 AM
02/89yota's Avatar
downloading now Thanks
Old 10-19-2011, 08:54 AM
JamesD's Avatar
Sounds like the timing chain jumped. Have you checked valve timing?
Old 10-19-2011, 09:04 AM
02/89yota's Avatar
no, easy way to check? lol
Old 10-19-2011, 09:05 AM
nothing easy about doing things the right way.
Old 10-19-2011, 09:07 AM
02/89yota's Avatar
breakin my balls guys! haha, I have dumped over 400 in parts because of what I have been told/read.. I take it, checking the timing is in the fsm?
Old 10-19-2011, 09:08 AM
yup, go find yourself a paper clip too. I try to test everything before I start replacing stuff. But then again, I don't got much to test since I have a carb'd truck and it's gonna stay that way. lol. As long as I got fuel, spark compression and the correct timing, nothing else in the way to tell the engine not to run. LMAO.
Quick Reply: Mass load of parts replaced, still no start
