MarlinCrawler Shifter Seat
Old 06-05-2007, 11:41 PM
91muddog's Avatar
I am going to order one this week.
I have a few questions first.
Sometimes its hard to shift into certain gears, will this help at all?
doesnt always go into reverse all the way, will it help?
Is there a write up on how to do this?
If not how do i do it?
Im not familiar with shifter boots or working on manual trans.
any and all help is appriciated!
Old 06-06-2007, 12:30 AM
Drama Queen/Banned
paxil4x4's Avatar
The install is cake:
Remove the shift console and or boot depending on your models trim.
Push down and twist the shifter retainer counterclockwise and shifter comes out.
At the bottom is your old bushing. I used forcips to remove mine because it was cracked into three pieces.
Mine shifts crisper after the install.
BTW It's also the perfect time to change your gearbox oil because you can pour it down through the top.
Old 06-06-2007, 12:54 AM
TNRabbit's Avatar
x2.
I had shifting problems for YEARS before I learned about this. It made HUGE difference in shifting into reverse! I'd had to "clutch & bang" for years and now I hardly EVER have to. If you have any problems when you get ready to do it, pm me & I'll talk you through it.
Old 06-06-2007, 05:44 AM
nmtoy's Avatar
Very worth it and very easy!
Robb
Old 06-06-2007, 09:35 AM
Epikos's Avatar
On models with the shifter boot as trim, how does that get removed? it looks like a solid rubber boot.
Old 06-06-2007, 09:41 AM
4Crawler's Avatar
http://toyota.off-road.com/toyota/ar...%20Replacement
Old 06-06-2007, 07:05 PM
TNRabbit's Avatar
There are actually 4 boots. The top colored one, two rubber ones underneath that, then the little bitty ones that seal the shifters. Getting the carpet out of the way is kind of a pain, but once your pull it all back (use a screwdriver like you're taking a tire off the rim), it's cake.
Go ahead & order the plastic bushing that goes on the tip of the shifter as well.
Old 06-06-2007, 07:47 PM
Fossilized
Staff
dropzone's Avatar
Roger: you have got to be one of the most resourceful people as far as helping people out with information...
This is a repair that I need to complete and thanks to you (again) you saved a ton of work in researching the process....
Thanks,
Robb
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
punks_is_4x4
02-26-2016 04:29 PM
83yotastockR
11
11-10-2015 06:54 AM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: MarlinCrawler Shifter Seat
