Manual transmissions: 4-speed vs 5-speed
Old 04-16-2014, 05:24 AM
Triple's Avatar
How do the final drive ratios of the G57 5-speed and G40 4-speed compare? I'm having trouble finding reliable info on this.
If a 5-speed can be sourced cheap, is it worth the trouble of swapping it into a pickup originally equipped with the G40? Are the physical dimensions of each transmission the same? Mounting points, etc? Would swapping trannies also require different brackets, driveshaft, etc?
G-off
12-29-2015 12:44 PM
mordell
09-12-2015 10:13 AM
zz_denis
09-06-2015 03:43 PM
kelly1450
09-02-2015 12:29 PM
Quick Reply: Manual transmissions: 4-speed vs 5-speed
