Manual Trans swap...
I got a 88 pickup and i blew the trans. and my dad wants me to put a manual in it 4 gas mileage. and i need tips and any tranny that work on my 3vze motor.
do a search this topic has been talked about alot recently. Ive got some info on it im my first build thread also.
Parts needed
Trans R150F is what your looking for 88- up 5speeds in from V6's
Can use R151F with the bellhousing off the R150F. R151F has a lower first gear
Clutch
pressure plate
T/O bearing
Pilot bearing
Master cylinder
Slave
Pedal Asselmbly
Lines which you can easily make your own but be sure to have a soft line in there
As far as wiring youll have to search that but it has all been done and can be done
one of the best swaps I ever did for my truck!
You can frind complete manual trannies for about $250 +- its just finding the deal.
Search and you shall find
Look at Marlin cralwer also for some swap parts like Master and slave along with clutch kits that I highly recomend over any!
Parts needed
Clutch
pressure plate
T/O bearing
Pilot bearing
Master cylinder
Slave
Pedal Asselmbly
well me and black sub went to the local u pull it and got a r150f tranny and transfercase out of a 88 4-runner v6 along with a crossmember, pedel assembly, master cylinder and slave cylinder and lines. just got to get new clutch and flywheel and pull out the ole auto and get to work on it.
The MC will work just fine. Hes going to have to drill out the firewall to mount it. Its not a basic bolt in you have to cut! But this is cake work!
Inside dash view
outside under the hood still need to cut the bigger hole inbetween the two mounting holes for the rod that conects to the pedal
Pedal assembly should bolt right in if not get one off a 90-95 truck or 4runner and youll be good it bolts right up.
You may also want to look into getting a clutch start cancel switch! Not a bad idea if you didnt already get one!
^^^cool well i have a parts 88 runner and just wasnt sure if it would work. fillsrunner4 you are the man!. did you post up this info in another thread? i dont think i have the pin out locations bookmarked.
heres afew links for the swap.
https://www.yotatech.com/forums/f116...mplete-126323/
some install pics
http://www.flickr.com/photos/elliotj...7602261412709/
some install pics
Yup, this info is posted in my build thread!
As for pinouts Im not sure about that stuff since I just put in a manual harness and ECU so I didnt have to deal with it. Plus the previous owner chopped the harness and so I needed a new one anyway!
yea the auto and transfer are a different breed all together. Hydraulically actuated and they share fluid even. not alot of motor swaps for them. if you ever need a new setup they are lots of $$$$$$.
yeah thanks 4 all your post im working on figuring out how to get the auto one out.. and tomorrow im prolly gonna work on getting my pedals in they came out a 94 runner and my tranny and master and slave came out of a 88 runner will post pics of swap..
thanks 4 all your post i just got to figure out how to get the auto one out. then tomorrow im gonna work on putting my pedals in and they came out a 94 runner and my tranny and master and slave cylinder came out a 88 runner. still need to buy throw out baring and cluch and rear drive shaft
crammit442
7
11-29-2017 12:30 PM
Poncho0206
07-10-2015 06:21 PM
