Manual trans. not shift smoothly
Old 12-27-2013, 07:07 PM
shalom's Avatar
1988 pickup 4x4 extra cab 5gear ok when shift any gear i feel the teeth of gear in any change run good but i think its not normal. The fluid of clutch pump was checked
What can be causes of this
Old 12-27-2013, 07:18 PM
scuba's Avatar
I'd start by changing the gear oil on the transmission. The synchros in the trans could simply be wearing out.
Old 12-27-2013, 08:00 PM
shalom's Avatar
What oil? I can find on pepboys or any other store? What grade? This syncro. Need down the trany are expensive?
Old 12-27-2013, 09:28 PM
scuba's Avatar
Owners manual states 75w-90 Gl4 or Gl5.
I prefer non synthetic GL4 in my transmissions.
Old 12-28-2013, 09:09 AM
93Xtra-Cab's Avatar
A lot of people recommend Redline MT-90 transmission fluid.
Old 12-28-2013, 01:16 PM
shalom's Avatar
Today change the oil, the proble persist.
Old 12-29-2013, 06:23 AM
osv
osv's Avatar
check the clutch free play adjustment, and also make sure that the bracket that holds the clutch pedal isn't cracked... it'll flex if cracked, and not allow the clutch pedal to have full play.
Old 12-29-2013, 12:45 PM
shalom's Avatar
All stand up to be its gve clutch slave its short, i put a spacer between slave and clutch bracket and feel better need little more space
Liadrin
04-25-2022 02:54 PM
crammit442
7
11-29-2017 12:30 PM
Liadrin
09-01-2015 06:44 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: Manual trans. not shift smoothly
