Manual to Power Window Swap?
Is there an easy way to switch the power windows on an
'88 Runner from power to manual? Is there room in the door already? Do I just have to buy a manual regulator and a crank and bolt it up? Thanks.
Swap?
I've asked the same question on several forums, and the consensus seems to be that the doors are the same, but you'd need to source the manual regulator, the crank handle, AND(most expensive of all!) the interior door panel. That said, using used but good condition parts, I figure it'll run me about $100 per door(if I have to do it), buying the parts from dismantler yards.
It's very easy, the doors are the same for manual and power. There are 2 different types of regulators and door panels, those with wing windows and those without.
I love my manual windows, I also disconnected the power locks.
Robb
Robb
honestly, the easiest way to go is to buy doors that are prewired and have all the stuff. just pop the door on, run the power to the battery or stereo wire, and your all set.
Pull all the electric crap out, and put the manual crap in. Simple.
I still don't see why you'd wanna go for the manual ones if you got power already. Maybe you should just find someone with manual windows that wants power windows, and swap doors, or something. I kinda like not having to lean over the seat, and stretch to the back just to put my windows up, but to each his own, and I've got a 4Runner, so I've got an extra 2 windows. Good luck on the swap
06-01-2021 01:51 PM
Johntom240
7
07-13-2015 12:18 AM
jon.r
07-11-2015 03:34 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
