manual conversion questions
Old 11-05-2007, 01:16 AM
lukeland's Avatar
I may convert my 94 runner auto to standard and Im wondering if I need to chnge the ecu or will the auto ecu be ok without the auto? Also, will my auto shafts directly bolt on to the manual trans? thanks for any help.
Old 11-05-2007, 05:06 AM
WFO
WFO's Avatar
Your driveshafts should be fine. They were the same when I converted my 91. The computer will be fine too. You will have to unplug your O/D OFF light because it will be flashing when the auto is gone.
Old 11-05-2007, 06:54 AM
Tdubbs05's Avatar
definitely do a search for this. there was a guy who did a full writeup on it recently. haven't heard of anyone using a manual ecu, not sure why because it seems like it'd be much easier. when you use the auto ecu, there's several things you need to trick the auto ecu into thinking. for example, need it to think the cars in park/neutral to turn the motor over. on the writeup that i read, the drive shaft was fine; only extended it a few inches or so which is already built into the stock drive shaft.
Old 11-05-2007, 01:09 PM
lukeland's Avatar
sorry guys, I re worded my search last night and found what I needed. thanks for the replies.
colasurdo
05-14-2022 07:21 AM
coleypull15
11-03-2015 07:41 AM
TURBOrunnerNM
07-22-2015 11:01 AM
rushw
07-18-2015 01:46 PM
KBar
07-13-2015 06:01 PM
Quick Reply: manual conversion questions
