YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 11-24-2007, 01:38 PM   #1 (permalink)
Personal Sales Rating: (0)
Chief_Yota's Avatar
MANUAL-ASIN HUBS INSTALATION! (from WABFAB)
alright here it is,took me about 30 to do both sides.
U NEED;
asin manual hubs (wabfab)
wrench + 12mm socket + 10mm socket +extention
torch
hammer
visegrip
TORCH IT DOWN:
__________________
If it's not broken, it hasn't been modified enough.
pickup 91 3.slo,along with "the money draining mod"
PROJECT SAS UNDER CONSTRUCTION
MY SAS BUILDUP AND MUCH MORE FONKY STUFF,check it out!!
http://www.yotatech.com/f116/yet-ano...s-pics-155676/
Chief_Yota is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 11-24-2007, 01:41 PM   #2 (permalink)
Threadstarter [OP]
Chief_Yota's Avatar
smash with hammer on the the bolts heads gently! and its gonna pop just like popcorn. take off the midle screew inside the axle under the cap and then take out the hub body. now your ready to install:
__________________
Old 11-24-2007, 01:53 PM   #3 (permalink)
Threadstarter [OP]
Chief_Yota's Avatar
and now ENJOY THE RIDE,AND FORGET ABOUT CV DAMAGE!
__________________
Old 11-24-2007, 08:29 PM   #4 (permalink)
leebee's Avatar
hehe, just wait till youre on a tight trail and have the wheel cranked hard and hear that noise. youll know it when you hear it, that will be your cv letting go. been there, done that, got the hat and shirt.
fix it asap, i let mine go and ended up having to do the whole spindle when the bearings siezed on the highway at speed. NOT a nice thing.
lee
__________________
93 sr5 v6 auto, 4x4
there are quite some attractive ladies on here with Toys. (compliments of ironmike)
ifsc 3(.0)
http://tlca.org
www.of4wd.com
www.sontt.com
leebee is offline
Old 11-24-2007, 10:27 PM   #5 (permalink)
kountry_boi's Avatar
do I put the aisin hubs in free or lock?
Also got hubs from Wabfab and it looks perfect and fast shipping!!!
my bet is that I should put it in lock and after bolting up I should put it in free to free the hubs
but I thought I saw on one page that I should leave my hubs to free when installing
kountry_boi is offline
Old 11-24-2007, 11:14 PM   #6 (permalink)
infiltrator's Avatar
Send a message via AIM to infiltrator
thats badass how much did those run you (4 right?)
__________________
Old Rig: '95 4runner | White | ISR | 193,000mi. | Totalled.
infiltrator is offline
Old 11-25-2007, 04:41 AM   #7 (permalink)
bigt's Avatar
infiltrator
you only put the hubs on the front because the rear wheels are always locked because you need your 4runner moving
check out wabfabs site... search in google.. or get a set from a junkyard and rebuild yourself
__________________
1991 hilux
stinky tail pipe , bus turbo whine and the steering wheel on the RIGHT side
trail rig/beater 1982 suzuki sj410, 1 litre 45 thorobreed ponies and as tough as a yota
Where you go is your buisness, getting you home is ours
bigt is offline
Old 11-25-2007, 04:51 AM   #8 (permalink)
8yota9's Avatar
ill tell ya. my damm hubs wont quit. the drivers side. the spring and the pawl just wont sit togerther right. so when in on uneven terain i lose my 4x4
__________________
1989 Toyota Pickup 4x4 3.0 5 Speed,203,551, 4" trailmaster lift,Marlin Crawler clutch, factory brush guard, 31x10.5R15 wranglers, K&N/isr mod, 2 KC Daylighters, Midland CB with Fire Strike mount toped with 6 foot whip,and cheap but efective airhorns
1984 22R sfa 5spd 4x4 excab 31.10.5 bone stock
1987 suzuki samurai loads of rust,rattle can black, and 205 tires
8yota9 is offline
Old 11-25-2007, 05:25 AM   #9 (permalink)
Vendor Sales Rating: (10)
Talking
Install on "free" and then test them to make sure they engage properly at "lock".
Quote:
Have you had them apart lately? Many times the big spring gets installed upside down and then does not work properly or folks put TOO much grease in there and it creates a suction and the hub doesn't work right.
Our Aisin manual hubs' page:
http://www.wabfab.org/aisinmanualhubs/aisin.htm
waskillywabbit is offline
Old 11-25-2007, 08:36 AM   #10 (permalink)
8yota9's Avatar
Wab fab u the man. opened it up today. fliped the spring and wala kicks like she should thanks alot!!
Andrew
__________________
8yota9 is offline
Old 11-25-2007, 08:41 AM   #11 (permalink)
Andrew
If you stand that big spring on a flat surface one end will sit flat and one in will sit off camber. Put the flat end on the pawl and the off camber end goes up next to the actual hub dial face when you screw it on.
I get quite a few manual hubs and you wouldn't believe how many I've seen installed upside down.
Old 11-25-2007, 06:50 PM   #12 (permalink)
now I have a new problem,
I just put in those manual hubs and now when I put it to FREE theres a loud grinding or weird noise coming from my left wheel area.
I did the hub test (spin wheel and such) but it didn't make any noise while jacked up. But when I go to the street and drive it the sound appears, but when I put it to lock there are no noise.
Anyone know whats wrong?
Old 11-26-2007, 04:22 AM   #13 (permalink)
8yota9's Avatar
Maby your hub isent fully unlocking? is it around turns maby a cv i have no idea tho> some one will chime in.
__________________
8yota9 is offline
Old 12-03-2007, 01:26 AM   #14 (permalink)
you know the black cone washers that came with the add hubs? the ones where it is underneath the hub body bolts.
Do I still use that when I install my manual hubs, because when I took out the add and put on the manual I still use that black cone washers.
I just read somewhere that the manual hubs weren't needed to pound a hammer for take it out, but I tried taking it out and it was an a** to pull out because that washer was inside to deep.
It might explain a lot of issues for me.
Old 12-03-2007, 07:02 AM   #15 (permalink)
Aisin manual hubs require the OEM split dowels or cone washers to mount properly.
There are numerous write ups on how to install Aisin manual hubs online for ADD and auto conversions.
Yotatech
4WD Truck
Paid Advertisement
Tags
1987, 4x4, asin, cone, hub, hubs, ifs, instilation, modified, pict, pppporn, samurai, suzuki, toyota, washers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
ASIN locking hubs, IFS 1988 Dingman The Classifieds GraveYard 4 07-06-2007 03:50 AM
Are ADD hubs pretty much just manual hubs that are always locked? GradSR5 95.5-2004 Tacomas & 96-2002 4Runners 29 11-14-2005 11:02 AM
WOOOHOOO! Got some Asin hubs! SoCal4Running 95.5-2004 Tacomas & 96-2002 4Runners 4 10-18-2004 08:43 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
