major issue with 93 4runner 3.0
Old 09-16-2012, 01:20 PM
Thomas133's Avatar
I have a 93 4runner and it has developed some major issues in the past day. it is running very rough after the car reaches operating temp. there is also no oil pressure at idle but the rpms are right about where they should be according to spec. 800 rpm at idle. i have also just found an oil leak coming from somewhere below the engine at the transmission. also when i put the car into gear ( it is an automatic) i hear two distinct clicks and then the trans engages. there is also a problem with compression, the head was rebuilt about a year ago, i have checked for a misfire, oil seems fine, same with trans fluid. i have no idea where to look please help
Old 09-16-2012, 01:37 PM
rworegon's Avatar
How does the coolant look?
The oil?
Any white smoke out the exhaust?
Old 09-16-2012, 01:38 PM
Thomas133's Avatar
the coolant looks fine, same with the oil. there are no signs that the head gasket has blown again. no smoke, no milky oil
Old 09-16-2012, 01:43 PM
rworegon's Avatar
Ok.
Transmission fluid level?
All ground wires tight?
Vacuum hoses in good condition and attached?
Old 09-16-2012, 01:51 PM
Thomas133's Avatar
transmission level is normal, and i have looked through all the vacuum hoses and all are in good shape and attached, still looking at all the ground wires, but i didn't think that a loose ground wire would be the cause of all the issues. am i way off and that could be it?
Old 09-16-2012, 02:08 PM
wii_tarded's Avatar
how old are your O2 sensors? Also, is your timing where it should be?
Oil pressure gauge on the stock dash isn't the best in the world...so don't put a whole lot of faith in it. Get out and manually check the 710 fluid.
I had a car that would click and rattle when changing gears from D to P or to R, turned out to be the bolts holding the Torque Converter on were loose. Real simple fix on that car, haven't looked to much at our trucks with the auto..
Old 09-16-2012, 02:13 PM
Thomas133's Avatar
this model only has one O2 and it is about a week old, timing is good a 5+. i knew about the gauge but it was just the first thing i noticed before all the other issues came up. i will have to look into the torque converter but would that also cause the other issues?
Old 09-16-2012, 02:15 PM
wii_tarded's Avatar
I don't think it would cause it to run rough
Old 09-16-2012, 03:27 PM
bone collector's Avatar
3.0 timing is supposed to be 10*...
Old 09-16-2012, 04:35 PM
Thomas133's Avatar
yea sorry went a double checked it is at 10.
Old 09-16-2012, 04:47 PM
rworegon's Avatar
Spark plug and wires condition? Distributor cap/rotor if you have one.
Dirty air cleaner?
An injector that is not working?
Old 09-16-2012, 05:07 PM
Thomas133's Avatar
Dirty air cleaner?
i check the spark plugs and the wires they are fine, as well as the distributor cap and rotor but not the injector. i will take a look and get back to you, would that cause all the issues?
Old 09-16-2012, 11:42 PM
TNRabbit's Avatar
PULL ECU CODES.
What kind of "trouble" with compression?
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: major issue with 93 4runner 3.0
