YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-24-2008, 02:40 AM   #1 (permalink)
Bundubasher's Avatar
Send a message via Skype™ to Bundubasher
Exclamation Major gear box problem...
Hi
Been away for a while (3 years in East Africa). Exported my vehicle out there in 2004, problem is I have recently been having some problems with my gear box: basicaly all is OK around town however when I go on a long run at 50+ miles per hour the gear box heats up drastically and I loose 1st, 3rd and 5th gears. However if I continue at speeds lower (say max 40 in 4th gear) evenyually the gears cool down and I can get it into 5th again. The problem then comes when stopping - I have to leave it long enough to cool so that I can get it into 1st to pull off. 2nd is a definate no-no when fully loaded (around 3000kg).
Anyone have any ideas as to what is going wrong and how I can sort it?
Thanks
__________________
Jeremy "Enzo" Elphick-Pooley
WWW.AFRICA4X4CAFE.COM
WWW.AFRICA4X4OVERLAND.COM
UK spec '94 4Runner 3.0 Turbo Diesel
Bundubasher is offline
Sponsored Links
To remove this ad, register today!
Old 07-24-2008, 05:14 AM   #2 (permalink)
WFO
WFO's Avatar
Have you checked the oil? Does it feel like the clutch wont let it go into gear?
WFO is offline
Old 07-24-2008, 05:32 AM   #3 (permalink)
The problem only occured after dropping the box and replacing the third gear thingy (it was kicking out of 1st and 3rd). That happened in Zim, I then drove about 1000km to Lusaka (at about 80kmh) in Zambia where I thought that might be the problem and changed both 4wd transmission and gear oil.
After a short test drive it seemed OK but after about 150km back on the road I experienced the same problem. Nursed it 4000km to Nairobi where I had the gearbox dropped and checked - my mechanic could see no problems and all tolerances seemed OK so we reassembled. Around Nairobi everything worked well, however after 6 months there we drove down to South Africa (about 6000km) again the problem occured and I had to nurse it home at 80kmh.
Now I'm going back to Africa to pick up the vehicle and want to get it sorted this time so any hints as to what I should look out for would be appreciated.
__________________
Old 07-24-2008, 05:34 AM   #4 (permalink)
When the engine is cold, the clutch etc works fine. Gear changes are smooth and clean - this problem only occurs after a couple of hours of continuous driving at 80-100kmh.
__________________
Old 07-24-2008, 09:15 AM   #5 (permalink)
just a 22re's Avatar
Send a message via AIM to just a 22re Send a message via Yahoo to just a 22re
try differnt oil and when it wont let you go in try leting the clutch out just a little bit when your trying to get into gear and see if it goes in or just drive with out the clutch if need be
__________________
GO TEAM LAZY!!
my name is ALLAN
yeah its a 22re 5-speed 4wd 1987 4runner with a cam, snorkel, welded rear
Quote:
Originally Posted by SwampThing View Post
Going wheeling and going swampthinging are two totally different things. Wheeling is doing something with the expectation of having fun in the process. Swampthinging is doing something and knowing you'll probably end up in a hospital in the process.
http://www.yotatech.com/misc.php?do=flashchat
www.myspace.com/whatsadisplayname
just a 22re is offline
Old 07-25-2008, 01:49 AM   #6 (permalink)
I'll try that. however what concerns me is the great amount of heat generated in the gear box - I've got a mul-t-lock bolted to the side of the box and this gets hot, hot, hot! Is this a clue?
__________________
Old 07-25-2008, 08:03 AM   #7 (permalink)
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Hmmm....don't know what a mul-t-lock is.
What kind of gear oil are you running in the transmission?
__________________
Matthew
Context is everything....
Quote:
Originally Posted by abecedarian View Post
freckles, shmeckles... that was your acne reflecting on my pearlescent skin.
Get smacked....join chat!
thook is offline
Old 07-26-2008, 02:21 AM   #8 (permalink)
mul-t-lok is a brand of padlock; for car security a plate is bolted to the gear box and that extends up into the cab. The low/high 2wd/4wd leaver (or the gear stick) can then be locked in neutral using a special U bolt and lock.
SAE 75W-90 transmission oil
__________________
Old 07-26-2008, 07:37 AM   #9 (permalink)
Targetnut's Avatar
Put some known good 75w90 api GL-4 oil in it. I'll bet that they used whatever they had, which is probably OK for beating around in the bush, But problems arise under sustained loads.
I will say though that being 1st, 3rd, and 5th is curious since those are the gears that engage in the rearward direction in the gearbox. So I guess it's possible that a collar is getting hot and slipping on the mainshaft and allowing things to get out of position.
But try the oil first
__________________
Targetnut
don't talk about it, just do it!
Precision Import Service
'93 2WD 22RE, Ported w/os valves, custom intake manifold, crane cam, 295cc injctrs, Supra AFM, Supra fuel pump, adj fuel pres reg, 70mm throttle, LCE header, V6 Taco cat, 14lb flywheel, Kevlar clutch, W58 and short shifter, 4.10 gears w/Truetrac, drop spindles and blocks, 245/50-16 Yokos on 16x8 wheels, 4WD fenders, bumper, and valence, skinned tailgate
Targetnut is offline
Old 07-26-2008, 08:05 AM   #10 (permalink)
Someone on another forum suggested:
Castrol MTF 1067 PLUS - fully synthetic SAE 75W/85W manual transmission fluid.
Just have to see if I can get some in SA before we pick up the truck in Zim.
__________________
Old 07-26-2008, 08:06 AM   #11 (permalink)
To be honest - I do not really understand the workings of the gearbox. Can someone point me at gearboxes 101?
__________________
Old 07-26-2008, 08:15 AM   #12 (permalink)
Targetnut's Avatar
Quote:
Here is some info, Manual Transmissions Basics
I'm sure you can find more with a more diligent websearch
__________________
Targetnut
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Potential major engine problem advice?? ridg4d 95.5-2004 Tacomas & 96-2002 4Runners 2 02-17-2008 06:07 PM
Major Drivability Problem khoopes 86-95 Trucks & 4Runners 2 08-13-2007 03:55 AM
Shock Install - Major Problem and a Question dynamo 95.5-2004 Tacomas & 96-2002 4Runners 10 12-14-2006 05:02 PM
Major Handeling Problem---Need Your Help Please 4x4Lamm 95.5-2004 Tacomas & 96-2002 4Runners 15 02-16-2005 11:17 AM
Major Problem? MattM1215 95.5-2004 Tacomas & 96-2002 4Runners 8 03-15-2003 04:02 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
