Machine shop painted cylinder head. Is this bad?
I got my head back from a valve job, and every surface is painted. Looks like it was painted before seat grinding and skimming head-gasket surface, but every other surface is coated. Is this going to effect sealing intake/exhaust manifolds, egr plate, fuel pump block plate, etc...? Should the paint be removed before assembly. Why would the head get painted?
they paint it for looks, now depending on how good they cleaned the surface before they painted it, but if it was me i would remove it just to know that u are getting a good seal to the head and u wont have a problem later down the road with leaks,
that should not be drilled all the way threw. most of the time the shop that did the work will put a item like that on to mark it as one that they did for any warranty
work that the customer might come back to them with. it should have numbers or something on it, that way they can identify it was there shop that did the work.
I had a plug like that on a head that I had machined and they told me it was basically a tattle-tail plug to see if the head got too hot if you try and warranty it...
My neighbor said the same thing about that thing I thought was a plug, that it falls off if it overheats/warranty thing. It does have numbers.
When I unpacked it I was hoping that it was just clean, but yeah, it's painted. Comes off with brake cleaner. They even painted the valve faces and then half-ass cleaned them later. Overspray on the springs...
I'm going to just clean the sealing surfaces with brake cleaner. Kind of ˟˟˟˟ that there's paint in the combustion chamber and spark plug threads.
I guess what pissed me off the most was shipping the old spark plugs in the same bag as the newly resurfaced head and all the resulting gouges on the headgasket sealing surface and exhaust manifold surface from the spark plugs rattling around. Why did I send it out with the spark plugs in the head?
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
