Lunchbox reverse
Good question. I think they operate the same, but i've only driven on once. I want to know as well. Another question is ENGINE BRAKING. Does the locker lock when engine braking with a manual, cause that would be a little dangerous to engine brake around slippery corners.
lockrite locks in reverse, and i dono engine braking wise...with and without the locker both my rears would lock up and slide if i did a sudden high R off throttle or shift down to hard.....
Yes, it locks on all the above.
I engine brake down big hills in any weather BUT snow. And when I do I match the rpms of the lower gear. I have never had it swing out while doing so except the first time I had the locker on a snowy steep hill. The lil ol lady beside me had a priceless look on her face
my lockright stays locked in reverse so i would say yes. and engine braking with a locker in slippery surfaces such as snow is a bad idea, i almost fell off my driveway doing that (steep hill with a big dropoff on one side) going around corners that would cause it to slide out pressing the clutch in and using the regular brakes is best, but after driving with a locker for a while you get used to doing that so its really not a big issue.
Ilovemountains
09-15-2015 04:17 AM
May-39
09-06-2015 01:05 PM
