LSPV replaced... rear brakes sticking?
Old 04-05-2012, 05:12 PM
altered's Avatar
hi guys
stuck for whats wrong with my runner
rear drum brakes are sticking after replacing Load sensing proportion valve
not to the point of locking up but it its making a noise when creeping forward or backwards, and the rear brakes occasionally stick more and cause a bit of smoking from rear wheels. i know i will more then likely need to replace the pads now but i dont want to do that unless i can get them to free up.
any help with what the problem may be would be awesome.
i could have bled in wrong order if that could be the problem.
order was LSPV (since i was there already) then furthest from master cylinder to closest to master cylinder.
cheers
Old 04-05-2012, 05:49 PM
rworegon's Avatar
Do this: furthest from master cylinder to closest to master cylinder and LSPV last per FSM.
Old 04-05-2012, 06:15 PM
angrybob's Avatar
Is there any drag on the rear brakes with no pressure applied? Jack up the rear axle and spin the wheels...
Easy things first - check the drum brake cage clearance / adjustments
Old 04-05-2012, 06:19 PM
angrybob's Avatar
What guidance besides 'the force' did you use to install the LSPV?
There are measurements and settings that need to be right. What kind of vehicle? 2WD/4WD, Truck/4Runner - it matters.
EDIT - Click here for the LSPV FSM section
Old 04-05-2012, 08:10 PM
altered's Avatar
4wd 93 4runner v6 3vze vzn130r
when i bought lspv was told bolts straight back in where the old one was
was not told about any measurements or adjustments
will check drums although im pretty sure they are dragging but as i said not locking up
will also try bleeding with lspv last now
are the measurements/adjustments in the link provided?
thanks for the replies
Old 04-05-2012, 09:30 PM
altered's Avatar
well after inspecting it while jacked up i noticed left rear drum brake is leaking oil...
dunno if that affects it but i assume it does but both move but with a bit of force applied.
will i need to replace the drum or does that depend on where the leak is?
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
Johntom240
7
07-13-2015 12:18 AM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: LSPV replaced... rear brakes sticking?
