Loud Tapping
Old 10-20-2010, 09:24 AM
Bigg Ant's Avatar
Loud Tapping
Have a loud tapping sound which seems to be coming from the rear of the valve cover. After reading some threads on here, I adjusted my valves, changed my timing chain (everything ),and tried loosening the valve cover to make sure it wasnt to tight. Still have the LOUD tapping noise and was wondering what else could it be? I seen a thread where a video was posted up and my truck sounds the same. How hard is it to change bearings if thats the problem? The tapping will start after I start the truck and throttle it.....it gets louder the warmer it gets and very loud while driving.
Old 10-21-2010, 04:23 AM
pruney81's Avatar
I know after adjusting my valves the injectors are making the most ticking noises in my truck right now. Are you sure it's coming from the valve cover and it's not the injectors? Mine are outrageously noisy.
Old 10-21-2010, 05:00 AM
TNRabbit's Avatar
Piston slap/Rod knock?
Old 10-21-2010, 06:51 AM
Philbert's Avatar
Don't all 22RE's sound that way?
I've had this since 2002, adjusted valves, changed timing chain, etc and it doesn't seem to disappear. I haven't done the injectors yet (in the next year.....), but I think they may be the culprit.
Good luck - keep us posted if you find the magic cure!
Old 10-21-2010, 06:57 AM
xxxtreme22r's Avatar
if we had a video of yours it would greatly help, or maybe even a link to the video in which you say yours sounds the same.
kind of hard to accurately diagnose any noises with just text.
Old 10-21-2010, 07:24 AM
TNRabbit's Avatar
Injectors are a "Tick" sound while rod/piston issues would be more of a "Clack" or "Knock"
Old 11-30-2010, 01:14 AM
jbuck07's Avatar
i have the same problem on my 93 3.0 hilux. i was thinkin that the valves needed to be tightened or maybe the rocker arms? its a loud clicking and i can hear inside with the windows up....
Corvoid
12-11-2015 11:21 AM
Davebarbier
11-03-2015 03:28 PM
Jdgarrison
10-01-2015 02:11 PM
beltcutter
09-30-2015 06:14 AM
JPV
09-28-2015 03:15 PM
Quick Reply: Loud Tapping
