Loud rattle when I push the clutch (22RE)
Old 10-22-2010, 06:33 PM
Skinamer's Avatar
I have a loud rattle that happens when I am switching gears while driving. It almost sound like the engine, but it only happens when i push the clutch to switch gears. It only last for a second, if i keep the clutch pushed in it it wont do it. Any ideas?
Old 10-23-2010, 10:52 PM
the_supernerd's Avatar
That sounds a lot like my muffler. It is rusty and rattles a lot when shifting gears. It is not too noticable under normal driving or revving.
Old 10-24-2010, 05:17 AM
Skinamer's Avatar
Originally Posted by razed
does it rattle if you are sitting still in neutral, rev the engine up then press the clutch?
Not sure, I will have to check and see. It sounds like the same sound that my engine makes when I start my truck for the first time in the morning. It has a loud rattle for a few seconds, but once the oil gets to flowing it stops. There is a certian RPM where my engine will make a rattle but only for a few seconds. It does it on the while reving up and stops once I get past that certian rpm and does it again on the way back down.
Old 10-24-2010, 09:06 AM
yotamonsta-'s Avatar
Mine used to do the same EXACT thing then a month later i threw a u joint after i replaced it never had the problem again! you might check it out....Also you might check you valves since you mentioned it not doing it after it warms up?
Old 10-24-2010, 10:39 AM
snobdds's Avatar
That is your timing chain that is rattleing on sttart up. It also sounds like your throwout bearing is going out. I think you have a few issues going on here. Time to break out your
Old 10-24-2010, 10:48 AM
Skinamer's Avatar
Timing chain and guides were replaced about 3 years ago with a kit from here: http://www.engnbldr.com/toyota_performance.htm
Old 10-24-2010, 10:55 AM
bobby_duce's Avatar
i had the same problem, it was almost tin sounding noise. i couldnt make the sound in my driveway only when i was driving so i looked around the bottom of my truck and it was my heat shield for my cat.
Old 10-24-2010, 12:59 PM
Skinamer's Avatar
how can i tell if it's my timing chain rattling? It definetly sounds like its coming from the engine.
Old 10-24-2010, 03:26 PM
Timing chain rattling would come from the front of the engine. The driver's side guide is the one that breaks, this means that the sound can sometimes appear to be coming from the alternator. Another sign is that it can sometimes sound like a diesel when you first start it for a few seconds.
Check all of the heat shields on the exhaust. If any of them have broken bolts or if they are loose then tighten them up and see if the noise stops. My muffler rattles when I shift gears. It kind of sounds like a bike chain in a coffee can if that makes sense.
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
HookahRoo
07-20-2015 07:06 PM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: Loud rattle when I push the clutch (22RE)
