Loud howling at around 55???
Old 04-23-2012, 07:23 PM
BUST'EM504's Avatar
Is their anyway to eliminate problems in the driveway or check certain items in while its parked
thanks
Old 04-23-2012, 07:45 PM
BoredOutnJackdUp's Avatar
Thats pretty vague...
Old 04-23-2012, 07:59 PM
BUST'EM504's Avatar
haha yea I know man sorry been try to track it down but been busy as hell. I am going to try and get a buddy to listen maybe we can narrow it down.
Old 04-23-2012, 08:10 PM
nothingbetter's Avatar
I agree with him ^^^ we need more info.
Old 04-23-2012, 08:13 PM
BUST'EM504's Avatar
Im going to check the fluids in the front and rear diffs. All the cvs and bearings up front are new.
Old 04-23-2012, 10:28 PM
wyoming9's Avatar
Red face
What kind of noise??
Bad bearing don`t howl more like a grinding or growling noise.
What kind of tires and size sometimes depending on the road surface they can really scream!!
When did this start??
Old 04-24-2012, 04:28 AM
dirtdobberoffroad's Avatar
Lets see it howls at highway speed correct?
If you swerve to the left and right at highway speed does the noise stop in one direction?
I have had rear wheel bearings howl after sitting a while (year +) they get rust built up on the rollers. And swerving back and forth you can figure out what side it is. If you wheel in mud a lot it never fails you will get water and mud where it does not belong.
So that is my bet the next thing would be a pinion bearing
Do you have fluid leakage?
Old 04-24-2012, 05:49 AM
TexFF's Avatar
My rear gears howl @ highway speeds due to the PO not installing & setting up the rear end correctly. But we do need more info.!
Old 04-24-2012, 06:12 AM
DIHOWARD's Avatar
Do you have a dog?
Old 04-24-2012, 06:26 AM
BUST'EM504's Avatar
Originally Posted by DIHOWARD
Do you have a dog?
Yes I do. ˟˟˟˟ if they are all this easy I'll get it done this morning
Old 04-24-2012, 06:30 AM
BUST'EM504's Avatar
Tires are a very mild all terrain that should be the problem.
No fluid leakage but I've only had the truck for a week so I'm still feeling ole girl out
JNapolitano
11-14-2019 07:46 PM
Corvoid
12-11-2015 11:21 AM
Davebarbier
11-03-2015 03:28 PM
JPV
09-28-2015 03:15 PM
93RedKrawler
09-25-2015 04:03 AM
Quick Reply: Loud howling at around 55???
