| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Losing power (esp. up hills) even after tune up
#2 (permalink) |
Maybe compression check at this point?
__________________
Preston Edwards 1992 4Runner SR5 V6 4WD (5 Spd.) 246,000 miles & counting 2" Downey coils, 32x11.5x15 BFG A/Ts, Rockcrawler Series 51 wheels, Magnaflow exhaust, Yakima roof rack, ARB bull bar, SAW Torsion bars, (4) PIAA 520s, Cobra 18 WX ST II CB w/ Firestik antenna, hp iPaq GPS 2008 Toyota 4Runner Limted 4X4 15,000 miles & counting |
#3 (permalink) |
You changed the fuel filter, but did you check the fuel pressure? Maybe it's starving for fuel.
MIke in AR |
#4 (permalink) |
Thanks AMP. Is there a way to do that at home without a guage, i.e. kind of a pass/fail test to indicate whether this is the issue or not? I live about 30 miles from the parts stores.
#5 (permalink) | |
Quote:
Thanks, regularguy. |
#6 (permalink) |
Another suggestion would be to check your timing. 5* BTDC with the diagnostics connector jumpered between TE1 and E1. Check your TPS setting. And pull the cat and inspect it, remove it and look thru both ends to see if it is plugged. The compression test can be done at home, just need to get a compression tester and follow the instructions. Lots of post on here and in the FSM link on how to.
Where in Central PA are you? Maybe someone is nearby to lend a hand? Here is a link to a FSM for more info for you to go along with the Haynes. FSM
__________________
Brad Work is for those who don't know how to plunder!! 92x-cab dlx 4x4 22RE, Pacesetter header, everything else is so stock it's not funny, cause I don't have the money! 04 F150 FX4 SuperCrew |
#7 (permalink) |
The FSM is VERY helpful. Use it. I have a 3.0 V6, so I'm not really familiar with the 4-Cylinder. However, there should be a place on the fuel rail near the injectors to check fuel pressure with a gauge. Be sure to do any fuel pressure testing with the engine overnite cold. Don't want any flames.
If your 94 is like my 92, you shouldn't have to drop the tank to get to the fuel pump fittings. There should be an access panel under the carpet beneath the passenger side rear seat. It's right next to the door jamb. Mike in AR Last edited by regularguy412; 03-13-2006 at 01:15 PM. |
#8 (permalink) | |
Quote:
__________________
#9 (permalink) |
Thanks guys, you've been generous.
To answer your question, Pirate, I'm in Liberty Twp, outside Danville, PA. I work in State College, though, which is about 75 mi. I usually take my truck, since my wife uses our 4runner. I'm familiar with compression testing, just don't have a guage here. I also don't have a timing light or anything, but it's beginning to look like I need to invest in a couple more tools. I've been reading on the O2 sensors, and it seems that they're recommended service items every 30 or 60K or something, but mines the original. I guess I should replace it anyway, but does anyone know whether it could cause the kinds of symptoms above, or is it more likely a fuel/timing/cylinder issue? Also, maybe I should mention that the idle is a little funky/rough *after* the truck warms up. From a cold start, it's fine for a few minutes. Thanks again guys. |
#10 (permalink) |
Hello all,
Just a follow-up here. Knowing full well that there is certainly more than one issue going on with these noises, idling, and power loss issues, I think I did figure out what happened with this loss of power on the highway. The filter in the little assembly (I can't remember what you call it) that leads to the EGR valve was all kinds of clogged. For the moment, I just removed the top layers of it and used the ol' shop vac to get some of the other crud (it looked just to be carbon deposits--after all, it *has* been on there for just under 200k miles) and put it back on. The parts stores around here didn't seem to offer that filter thing, not that it looks real complicated to duplicate. Anyway, long story short, the power loss issue is gone for the moment and it's back to replacing many other parts that are beginning to show their wear. Thanks to everyone who suggested anything, and esp to Pirate for the reminder link to the other manual. |
#11 (permalink) |
I have the same problem and I had a spare ignition module that bolts on top of coil was replaced and now the truck runs really well.I think it is from all of the rain we've been having outside.My engine is a 22re and now is running really strong.
__________________
Black 1988 4wd Pickup 22re / White 1988 4wd 22re /1990 2wd PU 22re |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| losing power | yotarunner96 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 03-29-2006 07:00 PM |
| 96 Tacoma losing power | 96Tacoma Guy | Site Feedback | 5 | 12-05-2005 08:02 PM |
| No power, terrible mpg esp. when cold | Collie | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-30-2005 11:02 PM |
| More Power Without losing Mileage????? | deathrunner | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 08-07-2004 02:17 AM |
| truck losing power Help needed! | ranma21 | 95.5-2004 Tacomas & 96-2002 4Runners | 23 | 10-07-2003 05:28 PM |
